02-24-2020, 04:06 PM | #1 |
Throttle cable
I'm changing out the rod throttle assembly on my 70 to a 71/72 cable type. I just picked up the entire assembly from a 72 at pick a part. Since the grommet is trashed as well as the plastic piece that locks the cable into the pedal assembly, I'm getting a new cable. They list 2 parts one for 2wd and one for 4wd. What is the difference?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-24-2020, 04:43 PM | #2 |
Carpe manana
Re: Throttle cable
My guess is length - 4wd motors were set closer to the firewall so I suspect the cable for a K truck is shorter.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-24-2020, 09:22 PM | #3 |
Roadtrip!
Re: Throttle cable
Correct. You will want the 4x4 or shorter cable if you are in the rear mount holes.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-24-2020, 09:38 PM | #4 |
Re: Throttle cable
I could not find the proper length cable myself . Ended getting the longer one and modifying it myself .
