Air Condenser box and blower motor removal
I'm looking for some tips and tricks for removing the AC condenser black shroud / box and blower motor. I've removed the actual condenser and the left side of the black box. But I'm afraid there are bolts underneath that are hiding... any hints on getting that sucker out?
I'm going to but a AC delete plate over the firewall holes and eventually install vintage air. In the mean time I'm trying to clean up the engine bay. Do I need to remove the passenger wheel well? Gracias, Fred
1965 LeMans * 1968 CJ5 1969 Firebird * 1970 GMC Truck 1975 Trans Am * 1952 Pickup 1979 Trans Am * 1982 Trans Am 1976 CJ7 * 2000 Trams Am Last edited by 1badtransam; 02-25-2020 at 03:38 PM. |
![]() Join Date: Apr 2017
Re: Air Condenser box and blower motor removal
If you've got a really skinny friend or a young kid who's into turning wrenches I think you can get to them. I'm neither of those, so I think it's easier to just pull the fender. You might be able to access them from underneath the engine bay and going in from the bottom right side of your picture to underneath your blower box. Maybe it's different on an AC truck, but on mine I was able to get it off without pulling the fender
1968 GMC C2500 Long Bed Fleetside |
It has been a long time but I think removing inner fender/wheel well will give enough room for Blower motor. Might need the hinge also?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Thanks for the info. I was afraid of that.
Since I'm not replacing any of the parts, I may just start cutting...
1965 LeMans * 1968 CJ5 1969 Firebird * 1970 GMC Truck 1975 Trans Am * 1952 Pickup 1979 Trans Am * 1982 Trans Am 1976 CJ7 * 2000 Trams Am |
Thanks again, I'll give a try.
Old member
Inner fender and hood spring bracket has to come out to get it out. The inner fender take the cab side bolts loose and should give enough room to reach the bolts in the bottom. Hood hinge has to be took off fender and slide forward enough to get the fan out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks Andy!
Old member
Inner fender yes not the hood hinge. just remove back bolt loosen front one and rotate hinge to clear. snug up the one bolt. It will stay in place till you put it back but don't shut hood.
