Old 02-25-2020, 10:31 PM   #1
TBONE1964
Cluster King
TBONE1964's Avatar
Pertronix users question
Hello all,
Any of you out there running Pertronix with stock tachs?
Sold a 6 cyl factory tach to a customer and he is concerned as well as myself as if there an issue. I think the pulse to negative side of coil should be the same???
Thank you I’m advance for any knowledge for this.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 02-25-2020, 11:28 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Pertronix users question
I had a Pertronix Ignitor II on the L6 292 In my '68 C/10 Stepside. I run an AutoMeter aftermarket tach. I never had a tach problem.
My buddy has a BBF 429 in a '72 F-250 longbed. He installed the Ignitor III. His tach wouldn't work. He called their Tech Rep. The guy said, if you want a tach go back to an Ignitor II. Or run a mechanical tach.
Ignitor 3 is some kind of multi-spark discharge, like an MSD.
The issue I had with Pertronix is that it burned out after 7 years. Ignition would kill above 3500 RPM -- usually on the freeway -- with the engine cold cranking in gear at 65 MPH --On/Off with the key and it would pop start at 55 MPH -- usually p!ssing off the guy behind you.
I called the tech line. They said to send the module in. I did, and never heard back from them. I went back to points for a year, then got GM type HEI.
I now run a regular HEI. Again no problems with my aftermarket tach.
Old 02-25-2020, 11:50 PM   #3
Old_Gold
Old_Gold's Avatar
Hey Tom, I have a pertronix II on my 350. I'm using the negative terminal on the coil to feed the tach on my efi controller, works great!
Jim
Old_Gold is offline   Reply With Quote
Old 02-26-2020, 12:00 AM   #4
davischevy
davischevy's Avatar
I have several. No problem.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 02-26-2020, 01:08 AM   #5
70cst
70cst's Avatar
I have mine in for years with no issues - 402BB
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-26-2020, 04:58 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have an Igniter11 and their matching coil on my 350. and my tach works but is always 5/700 RPMs higher than it should be for a given speed. I called Petronix and they told me to get a certain resistor which I did and put it in the line and nothing changed. I sure would like to get the tach working as it should or at least within 200 or so RPMs of where it should be.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-26-2020, 07:39 AM   #7
racerop
racerop's Avatar
I would think a right sized capacitor
would lower your rpm reading to the correct
range maybe a coil/capacitor in parallel
before the tachometer
racerop is offline   Reply With Quote
Old 02-26-2020, 08:17 AM   #8
Already Gone
You lost me at capacitor. What is that and where could I get one..
Old 02-26-2020, 11:23 AM   #9
davischevy
davischevy's Avatar
I'm sure you would already have noticed if yours was bent, but my son in laws reads fast. Apparently when I detailed it I bent the needle.
other Larry
Old 02-26-2020, 06:38 PM   #10
custom10nut
custom10nut's Avatar
I have the Mallory version of this, and have had it in for about 20 years now.
I’ve not had any issues with it interfering with the Factory Tach, in fact I just replaced the original tach and the new one reads very close to actual RPM ( I hooked up my Multi Meter while I was dialing it in).
Gone are the days of having to use a matchbook to adjust the points
That and the Tach works as it should, what ore could I ask?
custom10nut is offline   Reply With Quote
Old 02-26-2020, 07:28 PM   #11
TBONE1964
Cluster King
TBONE1964's Avatar
Thanks guys for all the help. I hate to see people fry these tachs because of lack of knowledge.
Appreciate it,
Tom
Old 02-26-2020, 07:50 PM   #12
Already Gone
Yes, I believe my tach is an original. If I knew for sure that buying a new one would cure my problem I wouldn't hesitate to get one.
Old 02-26-2020, 08:41 PM   #13
dmjlambert
dmjlambert's Avatar
Is there an adjustment?
dmjlambert is offline   Reply With Quote
Old 02-26-2020, 10:57 PM   #14
'68OrangeSunshine
Real hard to find a crisp new matchbook nowdays.
Old 02-27-2020, 12:52 AM   #15
Bob B.
Have a Pertronix Igniter on my GMC V-6, using a repro OEM style tach I had recalibrated for 6 cylinders. No issues, it has worked for years.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 03-09-2020, 09:08 AM   #16
jmader
jmader's Avatar
I tested my setup yesterday and my tach stayed around 700 RPM at all times. I don’t remember if I have the igniter or igniter II. I didn’t have time to mess with it any ideas what could be causing it?
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 03-09-2020, 03:46 PM   #17
TBONE1964
Cluster King
TBONE1964's Avatar
Does it matter if you cycle key from off to on?. Does the tach rest at zero rpm with key on or off or always stays at 700 rpm?
Old 03-09-2020, 05:01 PM   #18
jmader
jmader's Avatar
It resets to zero when I turn the key off. I didn’t mess with it too much because I don’t have an exhaust yet but it’s being installed tomorrow so I should be able to look into it further then.
1967 Chevy SWB K10
Build thread-
