Old 12-08-2003, 05:31 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
2 "how to" questions
OK,
How is the vent window and related hardware removed/replaced in the doors? Must the window and regulator be removed to change them? If so, how?
Also...I've never done work on a drive-line before, thus I've never changed a universal joint. When the clips have been popped out, how are they driven out of the holes? Big hammer?
Thanks.
Jeffrey
sactoC10 is offline   Reply With Quote
Old 12-08-2003, 05:41 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Can't help on the vent window, but i can on the u-joints...
I drive mine out with a vice and 2 sockets, 1 large and 1 small. I put the yolk in the vice, and put a large socket (bigger than the U-joint cap) one one side of the yolk, and a smaller socket (smaller than the u-joint cap) on the other side of the yolk. Clamping down the vice pushes the U-joint to the other side. Works rather well. The big hammer method also works pretty well, but i have found the vice mehtod to be a bit slower, but there is much less of a chance of whacking your thumb with a hammer . And it is more plesant too.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-08-2003, 06:16 PM   #3
cheatham
I need a brake!
cheatham's Avatar
Another tip about the U-joints. unbolt it at the back and unbolt the carrier bearing. The whole thing will then slide out of the tranny.
You may have already figured that out, but I laid under my truck struggling with it not realizing I just needed to unbolt the carrier.
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 12-08-2003, 06:27 PM   #4
1970blazin
Blazerless:-(
1970blazin's Avatar
I am wondering about the vent window also?
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 12-08-2003, 06:44 PM   #5
Paul72
Paul72's Avatar
I changed out the vent window on my Blazer, and I basically took everything out. You can get the vent window assembly out with the window rolled down, but I don't know how it would be getting it back together.
Directions: Remove the door panel and remove every screw on the inside of the door. It's really not too complicated, but I would do it when you can put it back together in a short period of time (so you remember where all the hardware goes).
I've got a disassembled door in my garage if you have specific questions.
Hope this helps!
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 12-08-2003, 06:52 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Okay, if you are changing the vent window ONLY, you do not need to remove the glass or other "guts". Do the following:
1. Remove inner door handles, armrest, and door panel.
2. Remove the 2 lower screws, and the one upper screw holding the REAR (latch end) glass guide channel in place.
3. Push the loosened rear channel as far back as possible. This will allow the door glass to slide back toward the latch end of the door. This is important because you cannot remove the old wing vent without doing this.
4. Remove 2 lower screws and 3 upper screws holding wing vent in place. If you have a 72 door, also remove the screw that reenforces the area where the wing vent enters.
5. Pull wing vent away from where it sits, them pull up and out. You will want to be careful not to ruin your door 'fuzzies" in the process. The vent has to be twisted 90 degrees as well.
To reinstall, reverse the process,
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-08-2003, 07:28 PM   #7
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
CPNE made it sound to easy. He's got the process right though. When i did mine it was a pain in the neck and i scratched the Sh*# out of my paint in the process. And you're window liner you might want to take that out unless you're really careful, cause when i did mine I tore my brand new one all to heck. GOOD LUCK
WRMZ71 is offline   Reply With Quote
Old 12-08-2003, 10:11 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I've replaced my driver side and did exactly what CPNE said above-real smooth and easy.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-08-2003, 10:28 PM   #9
Randy70C-10
Randy70C-10's Avatar
Good, you can help me put mine back together after I paint the doors.
Randy70C-10 is offline   Reply With Quote
Old 12-09-2003, 12:36 AM   #10
sactoC10
71 DELUX
sactoC10's Avatar
Thanks for these answers. Regarding the drive shaft, I have removed it from the truck already...just trying to figure these details out. I'd think that maybe a large C-clamp may work similar to a vice then, eh? The vice I have is too small for this job.
As for the windows...good to know these tricks, which is why I asked. I once had a 68 Mustang and had the guy at the local yard not showed me how to remove the regulator, I'd probably still have window falling down into the door!
I will print these out and see how it works!
Old 12-09-2003, 12:42 AM   #11
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
If you want to save yourself some hassle, take your drive shaft down to a machine shop and have them do it. A c-clamp won't be any good.
Cat Fuzz is offline   Reply With Quote
Old 12-09-2003, 03:25 AM   #12
1969 GMC
1969 GMC's Avatar
get a ujoint press, they are cheap, for the driveshaft...basically a big cclamp. i think you can also rent them if for some reason you wouldn't want to keep it.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-09-2003, 12:41 PM   #13
sactoC10
71 DELUX
sactoC10's Avatar
reason for u-joint question
I have these longbeds...with the two part shafts. So the one removed from the 70 is rather awkward to move around and store, being so long and flopping about. I don't know if they are worth anything, but regardless if they stay or go, I need to get the two pieces separated.
If I don't have to, I don't want to throw any money at it. Maybe the dude across the street will have a better vice I can use.
Thanks!
