Location: 3,018 feet above the SoCal/Mojave Desert region.
1/2 ton springs on 3/4 ton. Will they fit??
1969 GMC 3/4 ton. Search bar not working. Rear leaf 2 1/4 wide 52" long. Trying to lower the truck but keep the 8 lugs. Some say I can use 1/2 ton front coils, so lower coils springs are easy to find. Who make 3/4 ton drop spindles??? The truck has factory disk brakes from a 3/4 ton donor. I've already remove 2 leaves from both side of the rear. It leveled with front and rides a WHOLE lot better. But maybe 2 inches more all the way around. This is a lot to ask for, but hopefully I can get some more help here. Thanks all. Oh ya, the truck will NOT be doing anymore 3/4 ton work. Its retired now.
#2 | |
![]() Join Date: Mar 2000
Re: 1/2 ton springs on 3/4 ton. Will they fit??
Paul Jr @ GMCPauls |
I will concur. I used 1/2 ton coil springs to lower my 68 C20 with a 2" front and 4" rear. I measured fender lip heights before and after and I was within 1/2" of the advertized drops.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
