Old 12-08-2003, 06:20 PM   #1
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Rear Blocks on 72
Do you have to use special drop blocks on the back of a 1972 chevy or can you use normal full size truck blocks?
Thanks,
Ryan
Bagd72Chevy is offline   Reply With Quote
Old 12-08-2003, 09:06 PM   #2
SCOTI
SCOTI's Avatar
Leaf or coil??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-08-2003, 10:53 PM   #3
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
if it's a coil truck you need to order or make your own since there is only one U-bolt per side. The U bolt runs over the axle, through the bock and the trailing-arm then bolts on the bottom. I've got a set of blocks that are a bit over 2" that i ran on my 72' with no problems...I dont need them, PM me if your interested.
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 12-08-2003, 11:16 PM   #4
Bagd72Chevy
C10 Collector
blocks
Hey,
I tried pm'ing you but it said your inblox was full. I'm interested in the blocks. What do you want for them, and do you have U-bolts too?
Thanks,
Ryan
Old 12-09-2003, 12:04 AM   #5
PrimeredThunder
Back from the Dead
I cleaned out my PM box.
Heres a pic of the blocks. How does $20 plus shipping sound? Sorry no U-Bolts.
Kenny
Salem, Oregon
Old 12-12-2003, 09:59 AM   #6
MOTHERTRUCKERS
We carry the longer grade5 u-bolts with rolled threads.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 12-12-2003, 08:44 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Here's what they look like installed. I built these for my buddy's truck.
Old 12-14-2003, 05:40 PM   #8
terrym1
terrym1's Avatar
looks like just a piece of 2 by 2 sq. tubing about 8" long capped on the ends is this about right?
terrym1 is offline   Reply With Quote
Old 12-14-2003, 06:26 PM   #9
Tx Firefighter
Yep, that's exactly what it is.
Old 12-19-2003, 01:45 AM   #10
sactoC10
71 DELUX
sactoC10's Avatar
DJM sells a block kit with the U-bolts that I think retails for around $50 for 1.5" of drop with blocks. This is the cheapest one I've found anywhere, but I went ahead and had my own made. I had a machine shop create the U-bolts and had the aluminum cut at an aluminum shop.
sactoC10 is offline   Reply With Quote
