Old 02-28-2020, 02:19 PM   #1
Matt87chevy
Dual Tank Wiring Questions
Hey ya'll,
I'm having some issues figuring out how to wire up my dual tank. I have an 1987 chevy with the original fuel system with upgraded pumps and selector valve. I have the wiring schematic for the original dual tank setup and I'm trying to connect my holley dominator EFI to it.
Do I connect the fuel pump connection to the D terminal on the original system relay? or is there another way about hooking this up.
I've attached both wiring harnesses for reference. Thanks for the help.
Matt87chevy is offline   Reply With Quote
Old 03-18-2020, 01:33 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Dual Tank Wiring Questions
I don't think you need to use that factory relay in the current configuration at all. You need to wire a relay that the pump signal from the Dominator harness triggers, that would then allow power to that "E" Wire. Clear as mud?
Hart_Rod is offline   Reply With Quote
Old 03-18-2020, 01:45 PM   #3
Hart_Rod
Hart_Rod's Avatar
Your holley diagram below. The green wire out of the relay should "electrically" connect to E on the diagram above.
Old 03-25-2020, 08:43 AM   #4
Matt87chevy
That clears things up.
Thanks again for the assistance!
