Old 12-08-2003, 07:09 PM   #1
krue
Designated A-hole!
krue's Avatar
Blower motor ?
I am trying to trouble shoot my blower motor.
What should the switch positions be from top to bottom?
Mine only works in the position one up from the bottom.
I can hear the relay click.
What can it be? The resistor in the box is nice a shiny.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-08-2003, 07:10 PM   #2
krue
Designated A-hole!
krue's Avatar
PS mine is an AC truck so I have a high speed fan.
www.daveramsey.com
Old 12-08-2003, 07:32 PM   #3
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
from top to bottom should be
off
low speed
high speed
The very bottom position has never worked on mine,
One of your resistor coils up inside the air duct might be bad causing you to have low speed only. There are 2 coils in the duct one for high speed and one for low speed.
67Fleetsidedream is offline   Reply With Quote
Old 12-08-2003, 07:50 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I just repaired a truck with simeler problems.
From the top - Off/Low/Medium/High. The problem that I had was the fan relay. I could here it click, but it wouldn't go into high. I could get low and medium though. I replaced the relay and the problem was solved. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-08-2003, 08:26 PM   #5
krue
Designated A-hole!
krue's Avatar
I found my problem, the low was working but I couldn't hear it, finally looked at it. The high only works with ignition "ON" not in "ACC". So now I need a lever and some hoses and I can defrost my windows.
www.daveramsey.com
Old 12-08-2003, 09:28 PM   #6
Hutch
Hutch's Avatar
krue
Check the high-speed fan relay ground wire very closely.
It is behind the glove box between the heater a/c box and the cowl.
It has a ground wire with a short black wire that connects to the firewall via a mounting stud for the heater box.
Mine was broke due to there was not much length on it and it had broken.
The symptoms were:
POS 1 Low speed = very low you have to listen very close
POS 2 Medium= seems normal
POS 3 High= very slow but turning
There is also another ground in the engine compartment that also works along with this one and it is right off of the fan.
The ground wires for the high-speed relay are trying to ground through the attachment bolts of the heater shroud, which is non-metallic.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
