Old 03-01-2020, 11:57 PM   #1
Andy4639
Old member
Andy4639's Avatar
Talking 71 Rear mirrior
I picked this mirror up a few weeks ago and just got it installed tonight. I took the old GM mirror out and installed this Nissan mirror.
This mirror has compass, outside temperature and 3 garage door buttons. Plus it's auto dimming to. I can go to my dad's and program his garage door to it. You can also program it to do other functions also like turn on lights and unlock/lock doors if you the features in your house.
I also took some pictures of all 4 trucks together before it got dark.
https://www.youtube.com/watch?v=S0y-Fa7-qfw
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-02-2020, 01:58 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: 71 Rear mirrior
Nice upgrade, Andy!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-02-2020, 07:54 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: 71 Rear mirrior
Originally Posted by Stocker View Post
Nice upgrade, Andy!
Thanks, yes it is. I like the Home-link stuff but the old one in the ash tray just wasn't working good enough. It didn't have any range on it because of it inside the dash. I hoping the mirror will give me time to hit the button and just drive right in without waiting for it to open.
Old 03-02-2020, 02:49 PM   #4
54blackhornet
54blackhornet's Avatar
Re: 71 Rear mirrior
Andy can you explain instillation ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-02-2020, 02:53 PM   #5
StingRay
StingRay's Avatar
Re: 71 Rear mirrior
What Nissan is it out of?
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 03-02-2020, 03:25 PM   #6
Andy4639
Old member
Andy4639's Avatar
54blackhornet,
The one thing is it has to be on the windshield mount.
Pretty simple install though.
12 v hot when key is on for the compass & temperature.
12 v constant for the Home-Link if you want it to operate when the vehicle is off. Are as I did just hooked it to the 12 v key on.
Ground wire.
The other 2 wires are for the temp probe. Doesn't matter which way you hook them up.
To wire it in.
You need 12 volts acc, ground and temperature probe and wires.
12 volts go to both the orange and black/red wires. Orange is for the C/T read out. Black/Red is for the Home link.
Black is ground.
If your vehicle has a 12 volt constant you can hook the B/R wire to it and it will work anytime. Mine doesn’t have a constant 12 volts.
Temp Sensor:
Blue & Brown wires go to sensor out in the grille area. They can be hooked up either way. You will need to extend the probe wires.
To program the home link.
Have the car on.
Push the two outer buttons together and hold until the light flashes. This clears all old codes. Your done.
Next:
Have garage door opener less than 3” away from mirror and push both buttons together to learn it. The light will start blinking fast when it’s done.
Try the button on the mirror to see if the door opens if so your done nothing else to do. If not keep reading.
Next:
Find the learn button on the garage door opener and push it.
Go back to the mirror and push the same button as before. It should work and now your done that’s it.
StingRay,
The one I got I have no idea. I bought it off E bay. Most of the ones I have seen in the local yard haven't had the Compass & temperature both. That's why I bought mine. But most high end model Nissan have them. I bought 2 a few weeks ago thinking they had both but they didn't so I returned them.
Old 03-02-2020, 03:45 PM   #7
54blackhornet
Re: 71 Rear mirrior
I have above window mount ? What about the wires . How did you run them up ?
71 C-20
07 Magnum RT AWD
Old 03-02-2020, 04:34 PM   #8
Andy4639
Old member
Andy4639's Avatar
Re: 71 Rear mirrior
I ran them up the rubber of the windshield. I used inner com wires that I got from work. You can't even see them until you look close at the mirror where I tied them into the factory pig tail.
