Old 03-02-2020, 01:29 PM   #1
Brad54
Brad54's Avatar
Seat Selection Advice Needed: Sufferer of Analysis Paralysis
I'm months from needing to sort this out (or longer), but I need some direction non-the-less.
Truck Project: '62 K10 Long/Step resto-mod. 350, 4spd OD, NP205, Disc-brake open knuckle Dana 44 front, GMC Dana 44 rear.
Frame off, but with light patina paint job, because I'm going to use the truck for hunting, camping, daily driving, and light off-roading, so if the paint gets hurt I won't be upset.
I will spend a LOT of time behind the wheel of this truck.
So here is my question for the interior: I need advice on seat selection.
Gas tank relocated, and will have a '50s F1 Ford storage tray behind the seat for ratchet straps, gloves, and a tool roll. Will also have ax mount, and small shovel mount (Pioneer tools).
I have two dogs, so one of them is often with me.
Here are my seat options (and I currently have all of these... yes, I have a problem)
Tilt-forward stock bench seat, with canvas or black vinyl seat cover, or black vinyl with canvas insert.
Suburban 60-40 split bench.
60-'66 Panel buckets
'67-72 low-back buckets with factory center console with cup holders.
I would modify the Suburban bench to flip forward, using the flip bench's hardware.
I would also modify the low-back buckets to flip foward.
The low-backs have the advantage of the center console with cup holders. I use those in every vehicle I have, pretty extensively. But they DO become a catch-all.
I could do away with the console and make cup holders in the high-hump trans tunnel.
I could also use the factory '67-72 center console on top of the trans tunnel, turned around backwards like I did with a vintage console/cup holder in my '62 Suburban.
Looking for opinions on functionality and driving comfort.
Thanks!
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 03-02-2020, 02:30 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Seat Selection Advice Needed: Sufferer of Analysis Paralysis
Try one. You have options. Not difficult to change them out either. I can't see how any one else opinion of what you would like would be of any use to you.
Start at one of your options. Then you can post pictures and help the rest of us.
Old 03-04-2020, 11:56 AM   #3
AcampoDave
AcampoDave's Avatar
The comfort level off all your options should be relatively similar since they are all (ahem) vintage seats. I put a bench from a more modern truck in my cab, mounted to my original tracks, and even though my stocker was in good shape, it was still way more comfortable.
AcampoDave is offline   Reply With Quote
Old 03-04-2020, 12:31 PM   #4
VictoriaHardware
VictoriaHardware's Avatar
Originally Posted by Brad54 View Post
Looking for opinions on functionality and driving comfort.Thanks!
If you plan on driving it much, comfort should take priority over function.
VictoriaHardware is offline   Reply With Quote
Old 03-04-2020, 05:29 PM   #5
kens65fb
Thanks!
Here is what I got last month, I just ordered the console.
I'm aiming for a look like this.
kens65fb is offline   Reply With Quote
Old 03-04-2020, 10:09 PM   #6
DPowers
DPowers's Avatar
Put all three options on the garage floor and let the dogs choose... takes it out of your hands.
DPowers is offline   Reply With Quote
Old 03-06-2020, 07:42 PM   #7
Brad54
Brad54's Avatar
HA!
That's probably the best solution!
