Old 03-02-2020, 02:10 PM   #1
2nova2
Aftermarket Torsion Keys
Calling all users, I am getting mixed reviews on using these, I just bought an 04 2500 HD and running 285/70/17s and they rub a little when backing up turning, the truck is a little squaty in the front and I would like to lift enough for the tires not to rub. By using the aftermarket keys how much rougher will the ride be. Sorry if this one of those beat to death posts but I wasn't really seeing the answer in the search portion.
Jim
2nova2 is offline   Reply With Quote
Old 03-03-2020, 11:05 AM   #2
2nova2
Re: Aftermarket Torsion Keys
Anyone?
72 GMC Burb barn door 4X4 350/350 PS PB Tilt ( gone but not forgooten)
64 Chevy II V8 Loaded Wagon
2004 Chevy 2500 HD
Sonoma County, Northern CA
Old 03-03-2020, 01:13 PM   #3
jocko
jocko's Avatar
I bought leveling keys, installed them, removed them, and threw them away. Simply crank up tension with your existing keys to where you want (since it sounds like you just want to lift the front a little, maybe to level) - get the truck realigned at your convenience, and call it a day.
Old 03-03-2020, 01:42 PM   #4
2nova2
Thanks, I don't even care if level as much as clear my 285/70/17s which rub just a little when backing and turning at the same time, so I don't think I need much. How about shock length when cranking up, will I need extensions or longer shocks? or maybe I should get smaller tires like 265/70/17s
2004 Chevy 2500 HD
Old 03-06-2020, 12:48 AM   #5
Bladeboy1998
Agreed with what was said above. The aftermarket keys are a sham, I've ran my truck for over 150k miles with cranked factory keys and never had an issue. Even have original axle shafts. You won't need shock extensions because the suspension is still within its travel range. You could benefit from a set of bilstein 5100s for it, makes a world of difference. It's odd that your 285s rub, I cleared 285/75s without even turning the keys up, then I got my 315/75s and turned the keys up most of the way and they only rub just a little.
Bladeboy1998 is offline   Reply With Quote
Old 03-06-2020, 02:48 AM   #6
2nova2
Thanks for the response, unfortunately I purchased some already only after seeing a neighbors truck has them with no issues, I wish I would of got these responses earlier.
2004 Chevy 2500 HD
Old 03-06-2020, 09:47 AM   #7
hatzie
Moderator
hatzie's Avatar
Sounds like it varies.
I had rubbing issues with 285/75-17 tires on my 2005 2500HD.
I dropped back to 265/70-17 and those fit just fine.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-06-2020, 11:42 AM   #8
2nova2
Hatzie, does your truck have the torsion keys turned up or have aftermarket?
2004 Chevy 2500 HD
Old 03-06-2020, 04:09 PM   #9
2nova2
So I bought the Motofab keys from Amazon so I guess I can return them and buy some Bilsteins, thoughts on that?
2004 Chevy 2500 HD
Old 03-06-2020, 06:40 PM   #10
hatzie
Moderator
hatzie's Avatar
Factory turned up slightly so it's level. Doesn't matter... You can't crank them any higher than the OEM keys without changing the A-Arms for clearance.
