03-03-2020, 05:05 PM | #1 |
67-72 Independent Rear Suspension Project
Here are some pictures of the latest project. The rear suspension is a fully bolt in IRS kit using a fabricated 9" housing, 33 spline CV shafts, cam bolts to set rear wheel camber and steering arms for toe adjustment. |
03-03-2020, 05:43 PM | #2 | ||
"I ain't nobody, dork."
Re: 67-72 Independent Rear Suspension Project
Nice truck... but that sure is a lot of work and coin to "improve" on something (coil trailing arms) that already works perfectly.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-03-2020, 06:42 PM | #3 |
Very nice,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-03-2020, 07:05 PM | #4 |
I was going to say welcome to the forum since it’s your first post, but you’ve been here since 2008! Heckuva first post - some serious suspension work done there, nice job.
03-04-2020, 07:48 AM | #5 |
Old member
That's outstanding job sir! That thing should do well on the auto cross, if you plan to do that!
Ant no factory trailing arm suspension gonna handle like that will, that's for sure.
03-04-2020, 07:47 PM | #6 |
Impressive first post- nice work
71 C10 72 K20 72 K10 Super Kirk |
03-04-2020, 08:32 PM | #7 |
All about them K’s
Pretty slick. My Camaro has irs and it handles quite well for what it is. I’m sure that truck is a blast to drive. I sure hope it’s got a healthy helping of horse power to go with that setup.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-06-2020, 12:50 PM | #8 |
It currently has a 400 hp sbc with a really early Edelbrock multiport EFI, 700R4 trans and a 3.70 true trac Ford 9".
