Old 03-04-2020, 08:39 PM   #1
freds40
3 on the tree shift lever bushings
Does anyone have a lead on the shift lever bushings on the transmission end? I can find the bushing and sleeves for the column end as well as the clips no problem. I'm not having any luck coming up with the other end, even from sources that previously had them listed.
freds40 is offline   Reply With Quote
Old 03-04-2020, 10:56 PM   #2
rechinca
rechinca's Avatar
Re: 3 on the tree shift lever bushings
https://www.classicchevy.com/chevy-s...roduct_Related
Did you try this web site?
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 03-05-2020, 12:26 AM   #3
freds40
I did. The part number you posted is for the column end. They used to have a listing for the trans end of the linkage, but it doesn't come up on their site anymore.
Old 03-05-2020, 09:22 AM   #4
maverickmk
maverickmk's Avatar
Check out post #14, it may have what you're looking for.
http://67-72chevytrucks.com/vboard/s...d.php?t=798067
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 03-05-2020, 09:25 AM   #5
geezer#99
geezer#99's Avatar
Try your local speed emporium.
Parts store might have them too.
Look for hurst bushings like this.
https://www.holley.com/products/driv.../parts/3327302
geezer#99 is online now   Reply With Quote
Old 03-05-2020, 09:42 AM   #6
DjS71
Measure them out and see if McMaster has some that will work under 'Flanged Sleeve Bearings'
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
