Old 12-08-2003, 09:55 PM   #1
skokie
skokie's Avatar
What is this?
Does anyone know what this is?
skokie is offline   Reply With Quote
Old 12-08-2003, 09:57 PM   #2
knucklebuster
Failure is NOT an option!
knucklebuster's Avatar
looks like a egr blockoff to me
House payment or truck parts?????.........why does life have to be so complicated?
1969 Chevy Shortbed Fleetside
1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto)
1990 Ni$$an hardbody( daily beater that has been really beaten!)
1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me)
knucklebuster is offline   Reply With Quote
Old 12-08-2003, 09:59 PM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
That's what I think too! how's that column working out?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 12-08-2003, 09:59 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
It is a plate for mounting a divorced style choke on a Quadrajet carb.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-08-2003, 10:01 PM   #5
skokie
skokie's Avatar
Thanks. There is a lever on the passenger side of my holley that just nicks that thing and causes the holley to lift up. May have to break down and get a spacer. Unless I can remove it.
Old 12-08-2003, 10:01 PM   #6
Firefighter
Yellow aren't the EGR valve and the choke tubes mounted in the same place?
Yellville, Ar. USA
Old 12-08-2003, 10:05 PM   #7
lukecp
lukecp's Avatar
They may be.....
I have an Edelbrock manifold like his, #2101, and that is what it said the plate was for.....i had my choke hooked up to it when i had a quadrajunk still on the truck.
Old 12-08-2003, 10:27 PM   #8
skokie
skokie's Avatar
Column is working out fine black and blue. Just got to get this thing running now.
Old 12-08-2003, 10:50 PM   #9
Firefighter
Good deal, good luck with getting it running!!!
Yellville, Ar. USA
Old 12-08-2003, 10:52 PM   #10
walker
walker's Avatar
You can trim the part that gets in your way it is solid aluminum, at least mine was. You can probobly buy/make a flat one just as easy. It is the passage that exhaust flows through the manifold.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 12-09-2003, 01:47 AM   #11
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Thats the choke heater block-off.
Cat Fuzz is offline   Reply With Quote
Old 12-09-2003, 10:05 AM   #12
ckhd
ckhd's Avatar
That's exactly what it is.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 12-09-2003, 10:24 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yup, if the intake had an EGR valve port (and it does not) it would be aft of that.
Think about it, a big EGR valve there would completely be in the way of the carb.
Those block off plates are thick enough, just take your grinder and clearance it as needed.
Old 12-09-2003, 10:29 AM   #14
tom hand
CCRider
tom hand's Avatar
Thats exactly what it is AND you remove it to use the hot air choke that was on quadrajets around 75. Cut it, grind it, or make a flat plate
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-09-2003, 01:21 PM   #15
skokie
skokie's Avatar
Thanks Guys. Tx that grinder idea sounds good. I get a chance to break it in.
