Old 03-06-2020, 03:51 PM   #1
eric8
Flyweel info
So i've got a '77 C10 that's bone stock with the original 350 engine and 3 speed manual transmission. It's my understanding these applications came factory with a 168t, neutral balance (internal) flywheel. Looking at crate engines, some require an internally balanced flywheel and some that are external. Just want to verify, but if I get a crate engine that uses the new 1 piece rear main block, I'll still need to ditch my original flywheel, even if the new crate engine is internally balanced, correct?
I'm also trying to figure out, is a clutch specific to an engine? For instance, will an 11" clutch for a 350 sbc fit any manual transmission or vehicle that has a sbc? Or is the clutch specific to the transmission/vehicle?
eric8 is offline   Reply With Quote
Old 03-07-2020, 10:10 AM   #2
geezer#99
geezer#99's Avatar
Re: Flyweel info
Yupper!
One piece and two piece flywheels are different. Bolt pattern size is about 5/8 inch different.
Motor doesn’t care what clutch is used just as long as it bolts to the flywheel, fit’s inside the bellhousing and the spline count on the trans matches the disc splines. Some trans have 10 splines, some have 26.
Old 03-07-2020, 10:10 AM   #3
v30crewcab
v30crewcab's Avatar
Re: Flyweel info
one piece and two piece mains have a different bolt pattern for the flywheel.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-07-2020, 09:13 PM   #4
eric8
Re: Flyweel info
Thanks guys!
