Fit of pre-bent brake lines
This pre- bent brake line is not pre-bent very well
I can deal with the tweaking for fit, I have a problem with the pre-bent lines not fitting correctly in the stock brackets. I look at other install photos and it seems everyone has a different solution. What did you guys do ? What fittings did you use ? Up front the original brake lines are twice the diameter of the pre-bent kits. How did you fix the front hard brake line “T” to the frame ? This kit line stuff is all to small a diameter to fit proper to the original frame mounts. I am frustrated & want to move on. I could have saved money and time if I bent & built all the brake lines myself.
48 CJ2A 63 1500 GMC (LS1 w/ Muncie 4spd) 68 RS Camaro 71 K20 BBC & granny 4 speed 95 2500 4x4 17 HD2500 4x4 Want => 67 C10 short bed w/ Manual Tranny |
| Bookmarks |
