Old 12-08-2003, 10:21 PM   #1
chevykid1969
chevykid1969's Avatar
air bag
Is this a good start for a system. What else would i need(of corse bags) and how much for it thanksCompressor & tank kit
Viair 450 compressor,
5 gallon tanks with (8) 1/2" ports,
moisture trap,
PSI switch,
50' 1/2"airline, and fittings.
chevykid1969 is offline   Reply With Quote
Old 12-08-2003, 10:43 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
1/2" wow are you gonna hop it or what??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 12-08-2003, 10:54 PM   #3
chevykid1969
I have no clue when it comes to air bags.
I need guidance
Old 12-08-2003, 11:12 PM   #4
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
It's ok to run 1/2" line as long as you arent talking about inside-diameter of the line. With 3/8 valves the inside diameter of 1/2 line is also 3/8, since its the same you shouldn't have a problem.
Other than that, you sound like you've got a good start. any idea what bags and valves you plan on running?
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 12-08-2003, 11:22 PM   #5
chevykid1969
i have no clue i hoped someone would tell me
Old 12-09-2003, 02:07 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
There is lots of info to be had right here in this forum. Here's a thread where I have tried to answer some of the questions you are asking-Read this
See if this doesn't help some....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-09-2003, 05:54 AM   #7
NORCAL_GUY73
NORCAL_GUY73's Avatar
I am running a viar 450 at 145 psi and 3/8 ich valves are just too slow for the front if you want to play around a little. The rear is sweet with 3/8" due to lack of weight.
I am running Slam Specialties bags model #RS72 at all four corners and it rides very nice even with my tiny tires (35 series) all the way around.
I would suggest using electric valves over manual and honestly there is no real reason to waste moeny on air gauges except maybe for the front end.
Also you want to seperate everything, I would not recomend any tee-ing of lines even for the back, keep them seperate.
I hope this helped
NORCAL_GUY73 is offline   Reply With Quote
Old 12-09-2003, 09:30 PM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
......and honestly there is no real reason to waste moeny on air gauges except maybe for the front end.
Yeah, you don't need gauges unless you want to maintain a certain ride height every time you raise the truck and prevent your front tires from wearing prematurely.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-09-2003, 09:32 PM   #9
Izzy
Trucker.
Izzy's Avatar
I agree plus some people have a lean so they need to know what PSI to set on each corner.
Izzy is offline   Reply With Quote
Old 12-10-2003, 12:31 AM   #10
loweredd
www.loweredd.com
loweredd's Avatar
Dang NORCAL, I LOVE 221's.
I have 1/2 line all the way around with 1/2 fills, and 3/8th dumps. I think if I had a 175 pressure switch, the front might leave the ground for a split second. A very short split second.
You are off to a good list ChevyKid. The only other thing I would suggest is a relay so the compressor gets the most juice it can get, and switches. Dont forget valves. Dont get spools. I got those WAY back when when I did my 97 S10, and spool valves are Poop.
loweredd is offline   Reply With Quote
Old 12-10-2003, 10:55 AM   #11
Izzy
Trucker.
Izzy's Avatar
Get a Ford continuous duty solenoid if you run multiple comps. It can take more amps than a relay and will last longer.
Old 12-10-2003, 01:12 PM   #12
BaggedC10
Under construction!
BaggedC10's Avatar
I had no gauges and hated it. Besides, they're cheap and very useful. Dual needle gauges are the way to go---Compact and display each corner.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 12-18-2003, 08:15 AM   #13
NORCAL_GUY73
Don't get me wrong fellas, however I have 15 thousand miles on my suspension and the tires are fine. if your alignment is true you will not wear out yours ties too fast. I just dont see the point in finding a mounting place for gauges, most dashes start to look like $#^@#% when people add too many add-ons to them. I would recommend a dual air gauge for the front if you feel the need. I must just be lucky and haven't had a single problem. I commute 26 miles each way every day.
Happy baggin'
Brad
Old 12-18-2003, 09:29 AM   #14
SCOTI
SCOTI's Avatar
Norcal, I'd say your very lucky.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2003, 10:50 AM   #15
loweredd
www.loweredd.com
loweredd's Avatar
I drive 40 miles each way to work also, and have had no problems at all yet. I am going to add gauges though, cause I think I lean the front all the time.
