Old 03-07-2020, 10:16 PM   #1
Low69CST
Help Tracing Fuel Problem
Have a 87 half ton, 4x4, 350, and dual tanks. Before and after restoring the truck it had a periodic issue running on the auxiliary tank, which turned into an occasional problem running and getting a gas gauge reading. And now it just won't run or get a fuel level reading from either tank.
I got a new switch for the dash. Testing the wires I found the tan/white (#120) to be dead. I expected it to be hot. Thinking this was the issue I made a hot jumper and ground jumper for the tan and gray wires (#920 & #921). This did make the fuel gauge work, but the truck wouldn't run.
Thinking the tan/white (#120) being dead as the problem I traced the wire to the fuel relay on the firewall. I bought a new relay, which didn't fix the problem. Then began checking the wires in the plug for the relay with a test light. None of those wires were hot with they key on or while cranking. There should be some hot wires like the orange (#440) from the battery and the dark green/white (#465). It doesn't make sense to me that all these wires should be dead.
Any advice from anyone? The diagrahm shows a fuse on the orange wire (#440). Does anyone know where that is? I haven't seen it. Thanks.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
