Paint or Powder Coat ???????
My 70 stepper just came home from having rust repair and patina paint blended in where the rust was . Its almost time now to take the body off the frame so the frame can be disassembeled for blasting and Paint or Powder Coating . My question is what do you guys suggest , Paint or Powder Coat ? Its going to have LS Power and be a nice driver , nothing more .
![]() Join Date: Dec 2009
Re: Paint or Powder Coat ???????
If it's a daily driver.
I would paint it. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Yes , its gonna be a driver , a nice driver , but it will be driven anytime I have a chance once built .
![]() Join Date: Jan 2001
If you scratch paint you just touch it up. If you scratch powder coat, you're going to have to touch it up with paint, and there's always a risk that rust will develop under the powder coat. I say just go with a quality paint.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Jan 2007
Bingo
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
![]() Join Date: Nov 2018
I agree paint all the way. I've used Rustoleum on several frames and painted a couple of trailers with it, holds up very well.
https://www.summitracing.com/parts/r...+5ba2978eae099 |
I love a good powder coat as much as the next person, but with anything that will be exposed to road elements, rocks etc, I would paint to make it easy to touch up. I've been very pleased with my AG111.
Check out POR 15 frame paint,that is what I use. Just wire brush and brush it on.That's what it is made for. Check it out.....
If you go with powder pre-drill all holes needed so you don't drill thru the powder. I know it's a pain but on my frame off resto I removed all the brackets and cross members except the front/rear and the trailing arm cross member. The reason I did this so the paint can get behind the brackets and prevent rust. I sand blasted the frame and brackets, painted it and then bolted it back together.
Having said the above powder is much better as far as chip resistant. The key to choosing powder is a color you touch up with common paint colors. |
Catalyzed Rustoleum sprayed from quart cans. Simple and durable.
#11 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 03-09-2020 at 09:55 PM. |
Wood was locally sourced . My point is dont do anything half assed . If your going to put that much work into it do it right, cab is coming off this spring
#13 |
Almost Satisfied
![]() Join Date: Mar 2002
I did powder. It doesn't really scratch unless you really want to scratch it. Will handle chips much better as well. You don't want to take the body off to repaint and fix, so powder is the way to go IMO for a nicer build that you have put the dollars into. Just don't use contact cleaner on it....ask me how I know ;(
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
