Old 03-09-2020, 09:49 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
HEI question
Old blue has an HEI in it from the previous owner.
And it's a 20 gauge wire from an unknown source.
Anyways it broke off at the clip on my way to work Sunday, wired a temporary terminal end and went off to work.
And for a more permanent solution could I use a relay to operate the hei distributor?
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is online now   Reply With Quote
Old 03-09-2020, 10:15 PM   #2
jocko
jocko's Avatar
Re: HEI question
Ensure any resistance wire or ballast resistor is no longer present and use 12 gauge feed wire to the HEI power connection (all the way thru from ignition sw) and ensure full 12V present.
EDIT: also, recommend look at VetteVet's posts on this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=648300
Old 03-09-2020, 10:16 PM   #3
67C10Step
67C10Step's Avatar
Re: HEI question
As long as it provides 12 volts to the hei when the key is on it should work. 20 gage seems a little light.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-09-2020, 10:21 PM   #4
kwmech
Re: HEI question
14ga minimum. Can terminal into the same plug as the original resistor wire that came out of the firewall.
Old 03-09-2020, 10:45 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: HEI question
I was thinking 12 or 14g wire at least.
Was curious if there was any reason not to relay it and take the load off a 52 year old ignition circuit.
Old 03-09-2020, 11:03 PM   #6
truckster
truckster's Avatar
Re: HEI question
There's no reason you couldn't use a relay in the circuit.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-10-2020, 12:34 AM   #7
54Caddy
GM Addicted
54Caddy's Avatar
Re: HEI question
Depin the resists wire in harness pin in a new HEI lead. Works every time! Stop
By I’ll help you out
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-10-2020, 12:48 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: HEI question
You should've seen the mess I took out with a new to me cluster.
The other one was a disaster
Old 03-10-2020, 08:10 AM   #9
jbarron
Re: HEI question
I've had mine hooked to a relay for years.
Gives you some options for security.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 03-10-2020, 11:35 AM   #10
68 P.O.S.
Re: HEI question
There's no issue with running a relay.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-10-2020, 04:44 PM   #11
HO455
Post Whore
HO455's Avatar
Re: HEI question
I feel that adding a relay only adds one more thing to fail to the circuit. There are millions of HEIs running around without a power relay with no problems.
If you decide to remove the Resistor/Ballast wire here is a link to how I did mine. Scroll to post 387.
https://67-72chevytrucks.com/vboard/...698377&page=16
RIP Bob Parks.
Old 03-11-2020, 12:19 AM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: HEI question
I've read it only pulls 2-3 amps. Maybe I will have caddy help me re-pin it.
Old 03-11-2020, 02:24 AM   #13
lousyflyer
Re: HEI question
I used a relay because the painless harness had a smaller distributor feed wire than I was comfortable with. The relay is on the firewall, with heavier wire, and the path to the HEI is shorter now.
Before long the only original thing on the truck will be the rust.
lousyflyer is offline   Reply With Quote
Old 03-13-2020, 04:27 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: HEI question
Well, some multi meter testing showed 11.9v at the hot wire 12.5v at the battery.
14.2v at idle 13.6v at the distributor.
Got a new clip installed and going to leave it for now
Old 03-15-2020, 03:15 PM   #15
hjewell2
hjewell2's Avatar
Re: HEI question
He is absolutely correct top to bottom.
hjewell2 is offline   Reply With Quote
Old 03-16-2020, 02:51 AM   #16
toolboxchev
Re: HEI question
I have heard they should have about a 7.5 amp fuse. Have not had one blow yet and going to step it down to 3-4 and see what happens.
toolboxchev is offline   Reply With Quote
