Old 03-10-2020, 10:26 AM   #1
SwitchbladeII
Level z-bar/cross shaft?
While installing my clutch linkage (all new parts) I noticed the z-bar tilted down a bit on the motor side. Is this normal? The left and right alignment if fine. I am sure it will work ok but would like it to be level. The motor and bellhousing mounts are new. I guess I could shim the bellhousing mounts to raise the rear of the motor to level the bar. I have included a few pictures of the new and original linkage. The original was hacked and looks like it had more of an angle. Am I being too picky? I sometimes get to anal about my projects. I welcome all suggestions and advise.
SwitchbladeII is offline   Reply With Quote
Old 03-10-2020, 11:40 AM   #2
geezer#99
geezer#99's Avatar
Re: Level z-bar/cross shaft?
Yupper!
Too picky!
They sit like that.
Motor torques over to the passenger side which levels it.
geezer#99 is online now   Reply With Quote
Old 03-10-2020, 12:11 PM   #3
Mbeef61
Mbeef61's Avatar
Mines like that. And maybe a little worse. You can also check your motor mounts for wear which may effect it
Mbeef61 is offline   Reply With Quote
Old 03-10-2020, 12:28 PM   #4
Willys_MB
Willys_MB's Avatar
Mine is like that, too
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 03-10-2020, 04:09 PM   #5
SwitchbladeII
motor mounts are new.
Old 03-10-2020, 04:12 PM   #6
SwitchbladeII
Yeah, too picky! I have installed a bunch of these over the years but this is the first one with the nose off and looking straight in. Good to hear we are all in the same boat! Thanks to all!
Old 03-10-2020, 07:43 PM   #7
Mbeef61
Mbeef61's Avatar
I figured with how clean and tidy it looks
Old 03-10-2020, 08:15 PM   #8
SwitchbladeII
Getting there a little better than when I got it.
