Old 03-12-2020, 09:14 AM   #1
CG
BlahBlahBlah
Another rust removing question
So many videos on YouTube with people using large tote tubs and similar to soak their rusty parts in. Some use the ones suspended in the solution powered by batteries, some use solutions purchased at the home improvement stores that they just soak in. I bought some gallon jugs of vinegar at the dollar store and dumped a bunch of nuts and bolts in. Just shook it up now and then. Worked great for the little stuff.
Does anyone here have a serious set up of one kind or another going at home? Id love to see it if you do. I have what I think could be useful parts that need a good soaking of some sort. What system works the quickest?
Now that spring is just around the corner id like to get something going outside my shop in a couple of totes.
Old 03-12-2020, 09:55 AM   #2
Willys_MB
Willys_MB's Avatar
Re: Another rust removing question
How big of parts are we talking here? Home Depot sells "masonry tubs" or something like that. They're big, durable, and CHEAP. I usually use that for larger parts, but if you're thinking about something like a body panel I can't help you with that.
The bins I use are $6 for the one thats 28"x20" and $13 for 2'x3'. They're both about 8" deep, so you can fit most anything in there. I soaked my lower control arms in there to get the gunk off of them before I did anything else.
Links below:
Small
https://www.homedepot.com/p/Plasgad-...102C/205451585
Big
https://www.homedepot.com/p/Plasgad-...101C/205451550
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 03-12-2020, 10:04 AM   #3
CG
BlahBlahBlah
No big body parts, things like you are talking about. Those are nice looking tubs. I have a bunch of heavy duty totes Im not using anymore.
Love to see some systems in actual use that board members have.
Old 03-12-2020, 11:27 AM   #4
bubbasimms
I did my core support in a kiddie pool using electrolysis. Worked great.
bubbasimms is offline   Reply With Quote
Old 03-12-2020, 11:56 AM   #5
sick472
sick472's Avatar
Another vote for electrolysis...the parts can't get too big. I did the bedsides to my fleet after slpitting the spot welds. It took a couple weeks using a qualtiy battery charger.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 03-12-2020, 12:01 PM   #6
ohboy321
ohboy321's Avatar
I use reverse electrolysis to clean rust off of antique lanterns. It involves submersing the lantern in a solution of water and something to make it conduct better (washing soda), and then applying a low voltage to setup using a battery charger.
In my picture below you can see that I line the outer edge of the bucket with rebar. These are sacrificial and will rust up during the process. Connect the positive (+) lead to the rebar, and the negative (-) to the part to have rust removed. The lantern "after" picture below took about a week in the tank. That lantern is about 120 years old.
The process works very well. Reverse the leads if you want to make a new part look old.
I saw one guy make a large tank to de-rust a frame.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 03-12-2020, 12:07 PM   #7
raggedjim
raggedjim's Avatar
That's impressive! Good job, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 03-12-2020, 12:51 PM   #8
CG
BlahBlahBlah
Ok there ya go. Someone that uses this a lot for his hobby. Have you tried other methods to see if you liked those any better?
Old 03-12-2020, 01:02 PM   #9
Lanman1972
Lanman1972's Avatar
I like it.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 03-12-2020, 05:11 PM   #10
Mts67C10K20
Mts67C10K20's Avatar
I like the electrolysis method over chemical dips
No toxic to get rid of
I think I used borax (check goggle for concentration)
And a 24 v charger..power supply
Good luck
Mts67C10K20 is offline   Reply With Quote
Old 03-12-2020, 05:42 PM   #11
HO455
Post Whore
HO455's Avatar
I made a temporary tank out of some scrap plywood and some heavy guage plastic to dip a pair of fenders 10-15 years ago. The bigger the part the more power you need or it takes forever.
RIP Bob Parks.
Old 03-12-2020, 06:10 PM   #12
ohboy321
ohboy321's Avatar
When I first started to collect lanterns I tried a couple of methods I read about on the internet, including molasses. None of those methods take the rust off like reverse electrolysis.
I use swimming pool pH increaser for the sodium carbonate/washing soda. One tablespoon per gallon has been working for me.
The process creates hydrogen gas, so make sure you have good ventilation. I have read that using stainless instead of rebar creates poisonous gasses.
I have used graphite/carbon plates instead of rebar with good results. The plates don't rust like rebar so the water solution stays pretty clean and can go a long time without having to be changed.
Steve/NH
Old 03-12-2020, 06:34 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
There is a cat in Australia on Youtube using huge vats of molasses to remove rust from metal parts. It's main downfall, is that it takes a very long time. But it's effective.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-12-2020, 08:18 PM   #14
un4gvn!
un4gvn!'s Avatar
I started using Eastwood Rust Dissolver. I started with just a gallon to test it out. I soaked a very rusty brake bracket over night. The next day, I took it out and rinsed with just water. It looked like it was brand new. What's nice about it is it's water soluble and no toxic fumes. The bad part is that it's not cheap.
un4gvn! is offline   Reply With Quote
Old 03-12-2020, 08:28 PM   #15
72c20customcamper
72c20customcamper's Avatar
I use the electrolysis method on most parts and I use the same method to etch blades . Axe I made last week . But used salt and water and you reverse the polarity positive to blade negative to the sacraficiat rod causing the blade to etch.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-12-2020, 09:49 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
Stainless is iron, chromium and nickel. I suspect that the person telling you this had used some galvanized iron, which could present a problem from zinc content, if it bubbled out as zinc hydride. I know people who have died from zinc fumes from either burning the metal off to weld it, or not bothering to burn it off first. I realize that welding is different from an electrolytic bath, but the threat could still be there.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-12-2020, 09:54 PM   #17
franken
I've used molasses in 5 gallon buckets to giant garbage cans. It's cheap but not fast. I used to get it from the feed store in 5 gallon jugs. I did some steel wheels as well as smaller stuff this way.
I've also used phosphoric acid (concrete etch or cleaner) from the home store diluted for smaller stuff. Somewhat strong it works overnight.
franken is offline   Reply With Quote
Old 03-13-2020, 11:52 AM   #18
toolboxchev
Post up them pics! Killing Rust is THE thing to do!
toolboxchev is offline   Reply With Quote
Old 03-13-2020, 02:51 PM   #19
CG
BlahBlahBlah
I think I'm going to go ahead and give this a shot, reverse electrolysis. What is recommended for a battery charger? Can I use one from Harbor Freight (Ill wipe it down for the Corona virus)? I don't have a problem spending more money on a better version as long as its going to do the job just that much better.
I have a couple of sets of clutch/brake pedals that are kinda gnarly looking. They would be a great test.
Old 03-13-2020, 02:56 PM   #20
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Interesting stuff, I was looking for ways to clean small items without sand blasting.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 03-13-2020, 03:29 PM   #21
sick472
sick472's Avatar
Any charger will work up to a point. Don't try using a battery tender, but an actual charger. The biggest concern is how long it takes. I made a tank big enough to do bedsides (one at a time) and used, what I would call a heavy duty farm charger...(Schumacher 200/40/6A Farm & Ranch Battery Charger) and it took a couple weeks to get the job done set on the highest 12 volt charge setting (not the engine start setting - that would not be good I don't think). It took that long due to the size of the parts and the amount of water involved. I have used it for smaller containers and it cuts the time down considerably.
For 5 gallon bucket jobs...a more affordable charger would work just fine.
1972 C10
1985 K20
Old 03-13-2020, 03:37 PM   #22
toolboxchev
Thinking about doing this. Would anyone know if you need more amps or higher voltages for doing this?
Old 03-13-2020, 03:40 PM   #23
toolboxchev
I know someone doing knives, I have been over at his shop from time to time. Looking forward to making a knife this weekend out of bearing races, 52100, high chromium content.
How does this compare instead of using ferric chloride? I know the ferric chloride is fairly quick, but unknown how the durability compares.
Old 03-13-2020, 04:31 PM   #24
landarts
landarts
I went to Home Depot and purchased a large 55 gallon storage tub to use as a rust removal container that has a lid. Then I ordered a small container of Oaxlic acid from Amazon. Here is the link on Amazon https://www.amazon.com/FDC-Ethanedio.../dp/B01IPL7MZ6
I added half a cup of the acid to the water I put in the tub and stirred it up until it dissolved. I put in a few parts like the bench seat mounting brackets that bolt to the bottom of the frame and bolt the seat to the floor. I left them in there for a couple of days and when I took them out the rust was all gone. I read about this technique where bicycle collectors were buying old bikes that were completely rusted and taking the bike apart and using Oaxlic acid. It was amazing how all the rust went away and the paint and stickers on the bike were still there.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 03-13-2020, 04:34 PM   #25
sick472
sick472's Avatar
Here's one of the better write-ups on removing rust with elecrolysis...
http://antique-engines.com/electrol.asp
Simple and to the point with some added detail.
1972 C10
1985 K20
