03-12-2020, 08:15 PM | #1 |
Identify this part (possibly from A/C evap coil box)
I was taking my A/C evap coil out of my '72 C10 and found two of these laying on the frame rail just below the evap coil area right after I pulled the box apart and removed the coil. I have no idea where they came from or what they are. It's thin metal perhaps .020" or so. They do not have any engine bay type crud (grease and oil). They look galvanized with some corrosive pitting, but not really any dirt. This is how I found them. They look like they may have been inside the evap case. I've looked at the coil and case housing for any sort of 'imprint' shaped like this but see nothing.
I've looked at my build manual and don't see anything there. The service manual doesn't go much beyond the compressor rebuild. So, does this look familiar to anyone? I am ready to start putting things back together but don't want to start until I know where these guys came from. You should know that I've disassembled entire the front end to replace the radiator support and do panel repairs on the front sheet metal. It could be body shims that I hadn't seen because they were below the evap case. On a side note, if anyone knows a place to get quality gaskets for the heater/AC cases, I'd like to have some better quality bits than I've got in my current kit. They're pretty lame open cell foam. I tried Soff Seal but it seems they don't make a kit for us. Thanks for any help you can give. |
03-12-2020, 08:36 PM | #2 |
Re: Identify this part (possibly from A/C evap coil box)
If I recall correctly that is a shim used for the compressor mounting.
Jim |
03-12-2020, 08:51 PM | #3 |
Starter shim?
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
03-12-2020, 09:33 PM | #4 |
Carpe manana
x2
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-13-2020, 11:26 AM | #5 | |
Thanks! |
03-14-2020, 10:12 AM | #6 |
This forum is so great! I just looked at the LMC Truck online catalogue page for compressor mounting and those shims are right there in the exploded view.
Thanks again for the help. This place rocks. |
