Lord 2 and 1/2 in CPP spindles and cut one coil out of the springs
I have a 67 C10 2 wheel Drive the front suspension has been upgraded prior to me buying the truck I'm putting two and a half inch drop spindles from CPP and cut one coil out of the springs there seems to be a lot of discrepancy on proper assembly procedures. I'm replacing ball joints bushings tie rod ends idler Pitman please help me with some pictures in some simple descriptions of how I go about assembling the lower control arms Torx sequences and upper control arm assembly torque sequences thank you very much
Re: Lord 2 and 1/2 in CPP spindles and cut one coil out of the springs
Well on the 1st part, Jack up 1 side floor jack under spring area of control arm. Get it high enough to put jack stand (safety block) in center under the motor. Remove tire let the jack down so weight is on the control arm. I made a spreader like this....works great...[url]http://67-72chevytrucks.com/vboard/showthread.php?t=624464
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
BlahBlahBlah
