Old 03-13-2020, 10:54 AM   #1
Reno
Reno's Avatar
1972 K10 gear ratios
The tag on my front differential is 3.07 rear is 3.08 posi
My question is they always different on front vs rear by small amount?
Reno is offline   Reply With Quote
Old 03-13-2020, 11:51 AM   #2
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: 1972 K10 gear ratios
yep
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 03-13-2020, 12:07 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I believe up to 10% is allowable.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is online now   Reply With Quote
Old 03-13-2020, 12:25 PM   #4
ManNamedJed
Not always, but frequently. The different sizes of the differentials makes it impossible for them to match perfectly in some ratios.
ManNamedJed is offline   Reply With Quote
Old 03-18-2020, 04:47 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
http://brochures.slosh.com/pdfs/1972...20Suburban.pdf
Rich
1972 K5 Blazer CST Click HERE
Old 03-21-2020, 10:00 AM   #6
Mike C
Mike C's Avatar
ManNamedJed is on the right track. The ratios need to be close and some of that is dictated by what gear ratios are available in a given axle design. And some of that is based on general sizes of the gears themselves, carrier breaks, etc.
It is not a design parameter to have different gear ratio in front vs. rear. 3.73 is a good example of that.
In the case of the Dana 44 front where 4.09 is a common ratio, and a Dana 60 where 4.10 is the common gear. You see 3.54 in Danas and 3.55 in GM's. All of these are close enough as running 5 psi pressure difference in tires front/rear. Guys who run Dana 44 front and 9" Ford rear with the 3.54 front/3.50 rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
