Old 03-13-2020, 07:29 PM   #1
Tntruckowner
Wire connect top of gas tank
Anyone know of a trick for the wire connector top of sending unit my old sending unit had a eye for a nut to fasten and the new sending unit has a non threaded stud so I need the connector or some way to fasten it. And help would be appreciated
Tntruckowner is offline   Reply With Quote
Old 03-13-2020, 08:45 PM   #2
67C10Step
67C10Step's Avatar
Re: Wire connect top of gas tank
I had the same issue when I got my new sending unit and I just took a die and gently threaded the stud.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-13-2020, 08:55 PM   #3
Tntruckowner
Thanks that's pretty good idea
Old 03-14-2020, 09:25 AM   #4
Andy4639
Old member
Andy4639's Avatar
The butt connectors will work also. The female ends of them will fit on it. Are you can buy the correct wire and end for it.
The factory sendor had no threads. It takes the same connector as the cig lighter.
https://www.ecklers.com/chevy-truck-...RoC2UwQAvD_BwE
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-14-2020, 01:34 PM   #5
Getter-Done
Getter-Done's Avatar
Not sure what type you need.
Here is one on ebay.
Push On 90 Degree Wire Terminal For Stud
Free shipping
$7.50
eBay
https://www.ebay.com/itm/293334634250
84 Chevy K-20
