What gear ratio should I go with?
So I have a 70 short bed with a 454 30 over that's pumped with a th400 behind it. My plan the hole time has been to go with 373's in my 12bolt. Good idea or bad? I wanted a streetable hot rod that will go light to light but still be able to jump on the freeway. Your thoughts?
70 custom10 swb fleet side 454 th400 |
Re: What gear ratio should I go with?
I've got a 700R4 behind my 350 with a 3.77 12 bolt rear. Not a hot rod by any means, but its rapid out of the blocks with the 3.06 first (TH400 has a 2.48 1st). Too much right foot and all heads turn my way.
Fantastic on the highway with the 0.7 overdrive 4th and lockup torque convertor. 2200rpm cruising at 75mph (our speed limit here in South Africa). With the Th400 it was 3100rpm...
Best regards, Philip Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp ) Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12 |
if I was looking to set up that combination and have it do what you are asking for I would be looking in to adding a Gear vendor unit to the TH400
It depends on how your motor was built. Does it have a big lumpy cam built for high rpm power or a mild cam built for low end torque.
![]() Join Date: Apr 2005
Don't forget tire diameter plays a large part in this also...with that being said, I believe most factory Big blocks came with 3.08's unless ordered differently.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
A good converter is worth more acceleration than a deep gear. With the broad torque curve of a big block, you definitely don't need a ton of gear to get things moving.
But the converter is everything. The newer nice units from places like FTI and PTC don't exhibit much slip at highway speeds, run smooth and quiet, and let the engine get into the meat of the torque curve quickly. Anything from 3.23 to 4.11 would probably ET within a tenth of each other on a track.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
Post Whore
![]() Join Date: Feb 2016
My Burban has a 350 with 3.73's and 275/60/15's. I'm turning about 3000 rpm at 65 mph. If you are comfortable with that rpm for long trips then no problem. Personally with the generic small block (unbalanced, cast pistons, stock valve train) I have I generally travel at about 60 mph on the highway for long trips. That being said it is my daily driver and I would go to an overdrive before switching to higher gears with a vehicle as heavy as a Suburban. It had 3.07's in it when I bought it and acceleration was measured with a minute hand.
![]() So after all that yes it is a good idea.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
If it is a mild cam, dual plane intake 454 I would go with factory 3.07s a good posi And call it done. It’s so much nicer to drive freeway speeds with that gear and the 454 still has plenty of torque to lay rubber anyway. Sure, that freeway gear isn’t quite as much fun as a 3.73 but it’s so much more livable. Been there done that..........
Steve weim55 Colorado |
#9 | |
![]() Join Date: Oct 2009
I have 3.73s on my truck with a manual transmission. Short trips on the highway are fine, but I wouldn't want to take it on any trips where I'd have to maintain 70 mph for an extended period of time. It gets pretty loud inside at about 65 mph, and that is with quiet exhaust and a fan clutch. With a TH400 and no torque converter clutch, the rpm would be a little higher too.
If you are planning on changing gears anyway, I'd say go for around 3.42 or so. You're going to need some sticky tires if you want to get maximum acceleration with 3.73 gears and a big block. |
![]() Join Date: Feb 2004
I say OD also with the BBC. I run a 402 with 700R4(Monster) with lockup, 3.73 gear and 32 inch tires. Mine is a cruiser 4wd. The low 1st in a 700R4 may be to your liking lite to lite. I am not a converter expert however mine is a 1500 stall.
At about 1400 rpm with OD/lockup I am running 60 mph. BBC with stock 350 HP cam does not care. Gear vendors are expensive - been there. Dump the 400 for the street.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 03-15-2020 at 02:20 PM. Reason: words |
Light to light hot rodding and freeway cruising rpm are mutually exclusive gearing goals that can only “really” be solved, without any compromises, by an overdrive. Increase your ratio for the light to light and you raise your highway rpm. Reduce your ratio for highway cruising and light to light perf suffers. Overdrive retains the same off the line perf you have today (or will have if you swap rear gears) while enabling lower highway rpm. The only ways to introduce an overdrive is by an OD trans swap or an after-the-trans gear reducer (i.e. Gear Vendors overdrive, for example).
Since you have a warmed-over big block and it sounds like you intend to use it, I personally believe the TH400 is a good trans to stick with. The only trans I’d (personally) replace it with (for this specific scenario), to achieve your two goals, is a 4L80E – which is essentially a TH400 with an OD gear (and a bunch of electronics to deal with). It’s an involved and expensive swap. You can soup up a 700R4 and some have luck with that combo, but not everyone - but that’s also an option. The alternative, and a good application for your scenario imo, is the GV OD unit. It’s more bulletproof than the TH400, so it won’t be your weak link when you get on it. The additional capability a GV OD unit brings, when compared to an OD trans, is that it also allows the gears to be split, which in essence turns your TH400 into a 6 speed. In other words, the gear reduction ratio can also be applied to each gear, not just top gear. But to be honest, it’s probably not something of interest for running between stoplights – gear splitting is more applicable to motor homes and/or towing heavy loads up an incline. Having said all that, that’s just the gearing aspect of all this – none of us on here knows your big block and what “pumped” actually means – or just how seriously you want to go from light to light. You may indeed find that a low numerical ratio rear gear such as 3.08 or 3.42, etc provides more than enough acceleration and an acceptable highway rpm to make YOU happy. While folks’ input, mine included, may be helpful in your decision, only you know which tradeoffs you’re willing to accept or how much you’re willing to pay to eliminate compromise. Good luck! If you post your tire dia and current gear ratio, can post a pic of all the rpm data at various speeds for you. |
#13 |
![]() Join Date: Dec 2009
There are calculators on-line that might help you.
The T400 has a 2.48 to 1.00 in first; 1.48 to 1.00 in second; direct drive in third Link:http://www.tremec.com/calculadora.php Link:https://tiresize.com/height-calculator/ .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#14 |
here's an example for a 30" tire:
EDIT: and it shows why you would not want an O/D with a 3.08... (too low highway rpm) - and why you really need one with 4.10s if you're gonna spend time on the highway. I probably wouldn't use an OD with 3.42s as highway rpm gets a little low and highway rpm is not that bad to begin with in a 1:1 final drive trans, unless you're doing 70-80 all day long. Last edited by jocko; 03-15-2020 at 04:22 PM. |
#15 |
If you want impressive Stoplight--->
![]() Unless you have overdrive, you may not like it on the open tarmac. |
#16 | |
Post Whore
