Old 03-15-2020, 03:17 PM   #1
ccautoupholstery
Lower radiator hose
I am swapping an 01 5.3 into my 67. I have a jegs radiator that I plan on using but am trying to figure out a lower radiator hose that will work for me. The old lower radiator hose is 1 3/4" I.d. and the 5.3 lower hose is roughly 1 1/2-1 5/8 I.d. I'm hoping someone can help with a part # for a hose that works because every parts store employee around me is stuck on stupid...no part # they dont know how to help
ccautoupholstery is offline   Reply With Quote
Old 03-15-2020, 04:51 PM   #2
Daaaanz67
Re: Lower radiator hose
Maybe this one my fellow Idahoan. Hope it post.
Daaaanz67 is offline   Reply With Quote
Old 03-15-2020, 07:06 PM   #3
ccautoupholstery
Awesome thanks! Where in Idaho are you? I'm in Boise
Old 03-15-2020, 08:28 PM   #4
Daaaanz67
Star. Not sure if that will help you but I kept it in my photo archive for a reason and I think it was for the difference size on both ends. I used an adapter by Jags that run for my lower hose.
Old 03-15-2020, 10:04 PM   #5
ccautoupholstery
I was looking at adapters but just wasn't sure which one to order, figured one solid hose would be better anyways. AutoZone has that hose in stock so I am going to go measure it in the morning.(cant expect the employee to be able to measure it correctly) Star is just down the street, we should meet up some time after I get this swap done!
Old 03-15-2020, 10:40 PM   #6
Daaaanz67
Yep one solid hose is better. I used the adapter before I found that pic. Yep we can meet as long as you don’t mind a Idaho transplant. Some locals hate transplants.
Old 03-15-2020, 11:14 PM   #7
ccautoupholstery
Hey man I moved here in 2005 from Maryland. I don't care where you are from lol. Besides, you aren't in a Ford group 😂
Old 03-15-2020, 11:38 PM   #8
Daaaanz67
10-4 but am a car enthusiasts so I like all breads but lean more towards the bow tie. Once built a 64 f100 custom s/b. It was pretty special as the new owners took the original widow wife for a ride and sent me a pic.
Old 03-16-2020, 12:46 AM   #9
ls1nova71
ls1nova71's Avatar
That pic is of my truck, and I used the original radiator, so if your aftermarket radiator has the same size neck on the bottom it should work.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-16-2020, 02:01 AM   #10
Daaaanz67
Thanks Nova, I couldn’t remember who it was but had this pic for a long time just for the #. I give all the credit to you sir.
Old 03-17-2020, 12:39 AM   #11
goatless
goatless's Avatar
I was just looking for some the other day. O'Reilly's has a selection of them: https://www.oreillyauto.com/shop/b/b...0=1-1%2F2+Inch
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 03-17-2020, 01:08 PM   #12
pilotXC
I outlined it in my recap of when I did mine, sounds like you have the same issue I had using the stock radiator.
Try Napa part 7364.
http://67-72chevytrucks.com/vboard/s...d.php?t=796095
pilotXC is offline   Reply With Quote
Old 03-17-2020, 05:48 PM   #13
nsb29
nsb29's Avatar
Can I ask what you used for your upper
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 03-18-2020, 04:41 AM   #14
ls1nova71
ls1nova71's Avatar
I used the one that came on the Silverado. It's a little tough, but you can get the hose over the original 67-72 radiator fitting if you try.
