Auxiliary GPS speedometer?
Do any members run a GPS speedometer? One the sits on the dash or mounts in original cluster? If in the cluster, how was installation? Any suggestions on brand?
Thank you.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350 1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job 1953 Buick Special. GM 355. Just a good smooth engine. |
#2 | |
Cluster King
![]() Join Date: Nov 2012
Re: Auxiliary GPS speedometer?
That would allow stock speedometer. The speedometer would need to function correctly as well as be spot on with calibration. Hope this helps. Doing an actual electric speedometer conversion in the cluster is very expensive. If your not concerned with stock cluster then Dakota or Classic Instruments is my choice.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
I have an Intelletronix analog dash panel that I'm using with a Dakota Digital GPS receiver. It took some effort to get working correctly but once I figured it out it has been working fine and is very accurate. I've found that if I disconnect the battery for any reason it will take the GPS 10 minutes or so to boot up and the speed to display correctly.
#4 | |
The Older Generation
Here is my install many moons ago. I still have the truck and it is still working great. http://67-72chevytrucks.com/vboard/s...d.php?t=421745 LockDoc
Old member
I installed the speed hut gauge set in my 71 C 10. Its a easy job and it is dead on the mark. No matter what size tire no matter what gear you drive it and it's dead on.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I used the VeeThree gps that is sold by a bunch of others.
Installed it under dash close to a vent in an older truck(50) and it works good. It converts gps to a pulse signal that the gauge wants.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
I've used autometer phantom gps in my '80 c10. It works great. I have a gps app on my phone that I compared to a certified speedometer in a cop car along with their radar system. All three were exactly the same, so then I used the app in the c10 to verify the autometer and it reads the same.
Kind of a crappy picture, but this is the cluster assembly after I got it all modified. |
