03-15-2020, 06:37 PM | #1 |
Rally wheels
Picked up a set of 6 lug15x8 rally wheels today for my 70 C10 build. What are most of you doing to refinish them? I was thinking sandblast and paint or maybe powder coat. Thoughts?
03-15-2020, 07:25 PM | #2 |
Re: Rally wheels
Going to use trim rings? Scuff them down with 220 and them use filler primer and then 400 to get them even. Paint in your color of choice.
No trim rings? Paint as above or powder coat |
03-15-2020, 09:09 PM | #3 |
Re: Rally wheels
I plan to use beauty ring. I figure painting would be the best and probably the cheapest.
03-15-2020, 11:23 PM | #4 |
Re: Rally wheels
fine sandblasting inside n out, prime with gray primer outside and brown inside then spray black on inside first, let dry then spray outside with argent silver. looks factory
I BELIEVE IN JOHN 3:16 |
03-16-2020, 09:52 AM | #5 |
Re: Rally wheels
03,
Man, you and I could not be on more parallel paths. I have five of those exact same wheels for my truck. Currently they are under one of my work benches waiting to get to the top of the list. I'm thinking about having them powder coated if a local place will give me about the same price they quoted a buddy of mine. Mainly because I can drop them off and get them back way sooner than I'd be able to blast and paint them myself.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
03-16-2020, 11:10 AM | #6 |
Re: Rally wheels
eastwood sells argent silver in spray cans and its correct color
03-16-2020, 12:33 PM | #7 |
Re: Rally wheels
Whatever you do, make sure the surface where the tire seats is smooth and clean...
Duplacolor spray can DA1684 is close to Argent silver. I painted some of my Rayy's with it, I am satisfied with the color match... |
03-16-2020, 04:24 PM | #8 |
Re: Rally wheels
I had the same issue, shot them with the Silver Argent. Before and After shots.
03-16-2020, 05:43 PM | #9 |
Re: Rally wheels
I have the same wheels. I was on a budget, wire brushed ,sanded, primed and painted Argent Silver.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke Lariat 2007 BMW X3 2023 BMW X3 M-Sport 2020 BMW 540xi M-Sport 1995 Harley FLSTC |
03-16-2020, 06:21 PM | #10 |
Re: Rally wheels
Different wheels but single stage pewter is what I went with.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
03-16-2020, 06:36 PM | #11 |
Re: Rally wheels
Awesome! Thanks for all the replies!
03-17-2020, 09:44 PM | #12 |
Roto Reuter thats the name...
Re: Rally wheels
For my '70 K10 I had my rally wheels powder coated orange to match the truck. I also stripped the silver off of a good set of center caps to expose the chrome all the way around. I added 3" trim rings and of course some tires; a set of BFG All Terrain 33X12.5-15.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-18-2020, 10:36 AM | #13 |
Re: Rally wheels
My caps have the screws on the backside.
Smitty '71 Short Fleetside Spring Valley, Ca. |
03-18-2020, 10:59 AM | #14 |
Re: Rally wheels
I had mine blasted and painted at my work. We have a full paint booth, so they just took care of it for me.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
03-18-2020, 12:13 PM | #15 |
Re: Rally wheels
03-18-2020, 05:19 PM | #16 |
Re: Rally wheels
Pic
03-19-2020, 09:39 AM | #17 |
Re: Rally wheels
That's fine. It just means they are an early version, like 1975 model year.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-19-2020, 02:11 PM | #18 | |
Re: Rally wheels
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-19-2020, 09:39 PM | #19 | |
Re: Rally wheels
03-21-2020, 06:12 PM | #20 | |
Re: Rally wheels
03-22-2020, 08:18 AM | #21 |
Re: Rally wheels
I've done everything from cup brush on mini-grinder/spray bomb primer/spray bomb argent, to sandblast/bomb primer & argent, to blast/spray gun prime/paint, to blast/powder coat. They all came out really nice. I definitely like the sandblasting and feel it makes whatever else you do work out best. It not only makes it easier, it gives a surface that will grab that finish and hold on tight.
These were blasted and spray bombed.
03-22-2020, 03:18 PM | #22 |
Re: Rally wheels
If you can sandblast you should, particularly if you are going with a bright finish or bright color. And if you have the money to powder coat, it'll be worth it since there is no doubt it'll last.
I just wirewheeled and sanded my wheels and put a couple coats of rust primer on them. The silver argent didn't suit my truck, so I ended up using an engine enamel color that is kind of green/gray/black/ depending upon the light. Looks good three years later. Just spray can stuff, you might be going for a higher quality build than me: my truck needs a lot of work and I felt my money would go farther elsewhere. The repop caps are LMC specials that have actually held up pretty good. I like the look of trim rings, but I never run them because I don't have the heart to scratch my rims. Also, keeping a set of four trim rings in good condition is too stressful for me.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
