Nerf Bars
Who has installed nerf bars on your truck using the cab mounting points as instructions call for ?
I have but there seems to be a lot of flex from the rubber mounts , what am I missing here ? |
![]() Join Date: Jul 2015
Re: Nerf Bars
Following... was looking at installing bars or a single step,but slot of them bolt to the back side of rocker which to me isn't strong enough.
![]() Join Date: Nov 2018
Re: Nerf Bars
I've got a pair of SS ones I ordered along with new cab mounts that I have not gotten to installing yet. I could see right away that there is going to be way to much flex from leverage.
My plan is to get them mounted and positioned where I want them, then look at supporting them with a u-strap or such down from the floorboard of the cab to take away the leverage factor. I'll tackle it when I get them in position to see what the options are. |
#4 | |
Re: Nerf Bars
Re: Nerf Bars
I'm not excited about it either but I think if you tackle it with a good plan to limit the options for rust to get introduced it can be accomplished.
One option I'm leaning towards is rivet nuts installed with a good sealer and sealed again after all the components are in place, I believe it can be made very water/rust proof with a little pre engineering. Only has to outlast me! |
#6 | |
Re: Nerf Bars
#7 | |
Re: Nerf Bars
