Old 12-09-2003, 07:46 AM   #1
TIMSPEED
TIMSPEED's Avatar
What RPM do you shift at?
My truck normally shifts at 5000rpm, but when I revved it up tonight (to piss of the neighborhood) it spun up to 5500...so, should I shift higher than 5000rpm? But, how do I do that? Turn the screw in the shift solenoid? (TH350 tranny)
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-09-2003, 07:48 AM   #2
tecton
my auto shifts at 2.6 ot 2.7k
86k5/350
tecton is offline   Reply With Quote
Old 12-09-2003, 10:18 AM   #3
gldevall
gldevall's Avatar
When I get on mine I shift at 5500. You can get a shift kit that will hold it in gear until you shift it manually, however the one I have does not do this. If I pull it down to 1st gear it will shift out at 5500. Anybody know why it does this? 2nd I also shift out at 5500. And well 3rd if I'm at 5500, I should be doing about 110, whcihc I really do not want to do. These old trucks feel kind of squirrely that fast.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 12-09-2003, 12:07 PM   #4
stepside454
stepside454's Avatar
it depends on your engine. Ive seen guys rev there stock 350s to 5500RPMS. there actually making less power because there way out of a stock carbed 350s power band. its taking the abuse, & allowing the revs. but no need to do it, so you need to have some idea what RPM your cam & heads etc make power to. John
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 12-09-2003, 12:52 PM   #5
PHOENIX
I have stock 350 crate w/ 4-speed manual (granny gear) and I shift at around 4k when speeding around. If just driving regular I shift around 2300-3000.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 12-09-2003, 01:32 PM   #6
Tom
driving is in my blood
Tom's Avatar
Way too broad of a question. So many different motors, so many different peak power RPM's. I shift my 383 at 6000rpm because it makes peak power at 5500rpm. My vortec 350 never gets raced except for once and that was a 4500rpm shift. Stock its bottem end would take 6500rpm shifts all day long though.
Old 12-09-2003, 04:38 PM   #7
r0lf-
Hotwheels?
r0lf-'s Avatar
My shift kit shifts at 5500. But like posted above, its way out of the powerband, I can feel it lose power it just starts spinning faster and losing power
But My new heads and cam should fix that!
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-09-2003, 04:39 PM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
I shift my mild 350 at around 5000 rpm if i wanna go fast.....in drive it shifts at about 4200 rpm. If you have a pretty much stock engine, 4500 or even lower should be enough. You need to shift a few hundred RPM's above the RPM that your engine's power peaks....then you can carry a little RPM over to the next gear.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-09-2003, 05:15 PM   #9
Prerunner1982
Prerunner1982's Avatar
damn, my 350 when floored shift about 4000, the highest it have gotten it is about 4200. at that point i am going way to fast... normally its about 2500rpm.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-09-2003, 06:36 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Definitely a loaded question, but I can say pretty much 5300 is about the limit for a Stock SBC as 5500 is redline.
On the other hand, I shifted my BBC at 7200, and have been rarely known to go 7800.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-10-2003, 01:44 AM   #11
Dirty Dan
Oh Look Out!
Dirty Dan's Avatar
My truck shifts itself at 4500, I have let it rev to around 5200-5300. I have a single 3 chamber flowmaster so it sound alot higher than it actually is.
Dan's Webshots
"I have a lot of growing up to do...
I realized that the other day inside my fort" - Zack Galifianakis.
Dirty Dan is offline   Reply With Quote
Old 12-10-2003, 02:03 AM   #12
87 Shortwide
6600-7200 is where I usually shift when Im racing
Daily Driver: 1992 Blazer dropped on rallys
Project: 87 GMC shortwide, About to get a little boost
87 Shortwide is offline   Reply With Quote
Old 12-10-2003, 05:31 AM   #13
1969 GMC
1969 GMC's Avatar
I guess I drive like a grampa...If I am "racing" I shift at 3k, just regularly around 2k. I have an SM465.
Accidentally revved it to 6k once (don't ask).
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-11-2003, 12:44 AM   #14
1FaastC10
1FaastC10's Avatar
if the valves float, you know you're pushing it to hard.
1FaastC10 is offline   Reply With Quote
Old 12-11-2003, 10:04 PM   #15
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
1 gear shifts at 4800 RPMs. Valves float at 5200 RPMs.
If I run in 2nd. The tranny will shift up from 1st automatically to 2nd way past 5000 RPMs.
2-3 RPM shift unknown. The speedo runs out at 85 MPH in 2nd and ride starts to get hairy.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-11-2003, 11:28 PM   #16
swervin ervin
You get what you pay for
swervin ervin's Avatar
Put a TransGo shift kit in it and it will hold any gear until you shift if doing it manually.
I redid my governor to where mine will shift from 1st to 2nd at 5500 in drive. I shift at whatever it shifts at. I never use the Megashifter to shift manually.
As a matter of fact, I very rarely drive it hard anymore. I drive fast as usual, but not from a dead stop.
I see G still has that powerhouse 305 in his truck.
swervin ervin is offline   Reply With Quote
Old 12-12-2003, 02:54 PM   #17
gchemist
gchemist's Avatar
Your right Mike. Going on five years and the 305 has not died yet. Man it's time I get moving again. I'm getting ready to tear apart the replacement parts I took off a Suburban. I need to sand blast paint/powder coat the front a-arms. Removing the old bushings should be a lot of fun. :p Guess the garage will come in handy this winter.
Old 12-12-2003, 03:23 PM   #18
Tom
Tom's Avatar
Originally posted by gchemist
[B I need to sand blast paint/powder coat the front a-arms. Removing the old bushings should be a lot of fun. [/B]
G,
You ever going to stop worrying about everything else and start working on that motor we used to hear about from time to time?
