Old 03-19-2020, 07:02 PM   #1
howell57
6L80 trans shlifter
Anyone use a 2017 on Camaro style floor shifter in their C10? I added AN fittings for a trans cooler and they interfer with the column shifter.
howell57 is offline   Reply With Quote
Old 03-20-2020, 09:38 PM   #2
bigmoe
bigmoe's Avatar
Re: 6L80 trans shlifter
Pretty low. Would you build a console to mount it up higher? You’d also have to make sure the cable is long enough.
bigmoe is offline   Reply With Quote
Old 03-21-2020, 01:57 PM   #3
howell57
I built a console and it would mount on the cover. 2016 and back the shifter has a rod and 2017 on it is cable. One is cheap, the other hard to find.
Old 03-21-2020, 09:52 PM   #4
rowdy11
Howell can you send a pic or two? I'm just adding my AN connector for my 6L90 trans cooler and want to make sure I don't have the same problem with my column shifter.
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 03-22-2020, 11:42 AM   #5
howell57
Just got home from surgery, so won't be crawling under car for a while. I used 6AN 90's and pointed them at about seven o'clock to try to get them out of the way of the column shift rod. Two thoughts I had was that I should have saved the assembly that come off the frame rail and used it to come up with a way to shift trans. And the other way was to use a 2017 or later Camaro shifter on top of a console that I reworked. If you look at the 2016 or earlier Camaro shifters, they have a pivot arm and use a rod to the trans shifter. Too much cutting console and floor to connect it. Cable would be easier. Let me know what you come up with. I spent $70. for a Lokar unit I can't use!
Old 03-22-2020, 12:09 PM   #6
rowdy11
Thanks and feel better!
Lola: My Moon Shot
