03-19-2020, 11:54 PM | #1 |
327 question
Ok so I'm talking with a guy who runs derby cars and he has a 327 that he claims spins to 8,000 rpm and has 700 hp, full roller setup, vortex 208 ex 280 int heads, I'm not sure of the claimed torque numbers. He said it only runs for 20 minutes at a time, 30 max and never gets above 130°. Is this guy just trying to blow smoke or can a 327 actually pull off those kinds of numbers. I've never seen one that could pull over 500hp. Pictured is the motor
03-19-2020, 11:57 PM | #2 |
Re: 327 question
Ah, umm... let's see...
No. |
03-20-2020, 06:36 AM | #3 |
Re: 327 question
Since he has numbers ask for the dyno print out to back it up. No dyno...no proof, just blow'n smoke.
03-20-2020, 08:01 AM | #4 |
Re: 327 question
If’n it’s one of them thar super rare 5 bolt main nascar 27’s then them thar numbers are darn close!
03-20-2020, 09:07 AM | #5 |
Re: 327 question
A more reasonable figure would be possibly 400-425 hp. I'm not sure you could get those numbers from a blown or turbocharged engine with the cubic inch limiting it. I am building a 327 for my 55 now, and maybe, I can squeeze 340 out of it?
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
03-20-2020, 09:14 AM | #6 |
Re: 327 question
Yeah. I am too. I was told before I built mine that the 327 is limiting and expensive to build. I have double into it than I would have in a 350 engine to get hopefully 330 to 350hp. But I wanted a 327.
03-20-2020, 09:28 AM | #7 |
Re: 327 question
Thanks for the quick responses, I didn't think the numbers sounded right
03-20-2020, 09:51 AM | #8 |
Re: 327 question
Does he know it's the wrong color?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
03-20-2020, 10:02 AM | #9 |
Re: 327 question
The rpm is not out of spec for the right configuration, and 327 are pretty happy at that level.
A guy I used to know owned a dyno shop. A 327 can pull 500 hp NA, but it will not be on nodding terms with street ability. The one he was testing, and tuning laid down 535hp, and something like 340tq. Spun to 8500 rpm, and sounded like Satans chariot at idle. Though it was on note above 4500 rpm. I asked him about the specs, and he said huge. 12-1 compression, and a 600 lift solid roller cam. With the rockers where the stands bolt to the heads. Not the stud type SBC's have stock. Forgot the proper name. 700hp requires boost of some kind or your fully into nascar spec stuff, and it would need to pull more rpm to work. https://www.popularmechanics.com/car...ctually-stock/ Last edited by Ziegelsteinfaust; 03-20-2020 at 10:11 AM. |
03-20-2020, 10:42 AM | #10 |
Re: 327 question
vortec heads have a intake runner of 170 CC , no way they can put out that much power at those RPM's
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
03-20-2020, 09:53 PM | #11 |
Re: 327 question
Painted ford blue? That alone should tell is he’s full of BS
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 03-21-2020 at 03:53 PM. |
03-20-2020, 10:09 PM | #12 |
Re: 327 question
I see a long water pump, small balancer with larger pulleys, and I don't see a dipstick on the driver side...........305 for sure!!
03-21-2020, 04:33 AM | #13 |
Re: 327 question
Yeah, Ford Blue trips my wire, too. See if you can get the stamped numbers/letters off the block. The 2 or 3 letter code will tell you the factory displacement.
03-21-2020, 06:12 AM | #14 |
Re: 327 question
He's wasting a phenomenal racing motor on derby where a stock engine could just as likely win. I don't know about his numbers, but a 327 has huge potential for the displacement. I know people throw around their 500hp figure like they used to throw around 300hp. I guess that will need to be increased here before too long. I don't know about 327s being so much more expensive to build or hard to get power from. I have one I easily and economically built at 325hp and it cost me $1,300
03-21-2020, 06:32 AM | #15 |
Re: 327 question
10,000 rpm 283
https://www.youtube.com/watch?v=s-EuchNoI5M
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
03-21-2020, 06:35 AM | #16 |
Re: 327 question
