Undercoating Cab Question
Ok I got my cab in epoxy primer and I'm wanting to put some undercoating on it. I've searched the board but most of the threads are outdated and I would like information on the latest products. I've used Raptor on my '89 Toy and Jeep bumpers while easy to spray it seems a bit brittle. So I have a couple ?questions:
- What undercoating product would you recommend and why? - I want to make sure I get the whole bottom of the cab so should I lay it on the firewall or back of the cab? |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Undercoating Cab Question
Since you've already epoxy coated it I'd get a cheap spray gun and either shoot it with rubberized undercoating like this, https://www.amazon.com/dp/B07W7MBN7H...xpY2s9dHJ1ZQ== You'll have plenty left for inner fenders, bottom of the bed etc... Some people like "Lizard Skin"...? Never used it so...Lots of rattle can options on Summit. That Woolwax product isn't a rubberized compound, it's a slick film like paint...But again, it may be overkill if applied over epoxy coatings...A rubberized coating helps deaden sound and would protect that epoxy coat...Check out Summit for options, they have their own name brand for cheap, a fella could score a case and wouldn't have to bother with a spray gun...I like to shoot the insides of the rockers and cab corners too...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() Last edited by Ironangel; 03-21-2020 at 04:34 AM. |
I used the Raptor Liner...don't know how brittle it is, but plan on 2nd coat with rubberized. For sound proofing.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
![]() Join Date: May 2017
I've been using Eastwood's undercoat
It dries fairly smooth and stays plyable with a mat finish |
Post Whore
![]() Join Date: Feb 2016
What end result are you looking for with the undercoating? Noise reduction, heat blocking, corrosion prevention? I have not found a solo product that excels at all of these.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
For the bottom of the cab I am looking for a textured rustproofing preferably rubber based. I want make sure when the cab flexes it does not crack.
For sound proofing I am planning on using foil backed Dynamat, Fatman, or the like. |
I've had very good luck with the spray can rubberized under coating. I would lay the cab on it's back and then spray.
Also using the spray can under coating after painting the cab it's easily touched up. Having said above my projects will never see any salt again. |
Post Whore
We used the 3M or SEM rubberized coatings with a Schultz gun at the body shop. Cheaper than rattlecans. And its easier on the finger.
https://www.google.com/url?sa=t&sour...vK6OUnSCzfhRn7
Has anyone used AL's liner. Looks like it would suit my needs but not sure.
https://www.ebay.com/itm/Als-Liner-A...g/312711103398 Also, looking at Transtar. Again anyone use it and if so what are your thoughts on it: https://www.ebay.com/itm/Transtar-43...n/141370975125 |
