Old 03-21-2020, 02:21 AM   #1
variationperson
variationperson's Avatar
balls joints and tie rod
I need some help.I have a 1969 GMC Truck that's has drum on it ,but i want dis brakes on the front so I bought front end off a 72 chevy truck front end .My question is what tie rod ends and ball joints do it i lmk .thanks
variationperson is offline   Reply With Quote
Old 03-21-2020, 03:39 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: balls joints and tie rod
Summit has the CPP kits for as cheap as anywhere...This kit has the trailing arm and control arm bushings... https://www.summitracing.com/parts/c...SABEgIEHvD_BwE Or, go to Rock Auto online and cross reference the part numbers for 1972 Chevy C/10 and get Moog parts...Once you get the part numbers you can shop around for the deals. Rock Auto kills you in shipping. Make sure you specify parts for the 72 C/10 because some of that stuff is unique to 72's only...Good luck
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-21-2020, 01:41 PM   #3
toolboxchev
I got my complete front end from Jegs. All Moog components, all matching batch numbers. They were all made at the same time, from the same facility.
Not very expensive and excellent service from JEGS.
toolboxchev is offline   Reply With Quote
Old 03-21-2020, 02:01 PM   #4
REDROCKER652002
Having dealt with my son's 69 and not knowing what parts were in it. I would say go for the whole kit. You know everything is right and you don't have to deal with trying to figure out what fits and what doesn't. Just my two cents worth.
REDROCKER652002 is offline   Reply With Quote
Old 03-21-2020, 02:18 PM   #5
67C10Step
67C10Step's Avatar
If you got a complete 72 front end then everything should be 72, provided you got the drag link as well.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-21-2020, 04:10 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Ball joints and tie rods have to match the year spindle you use.
Hopefully you have the 72 centerlink. Then everything else will work fine.
Keith
Convert to disc brakes.
Old 03-24-2020, 03:34 AM   #7
variationperson
Thanks Guys for ur help .I went back and got the ties rod stuff from the 72 truck that I got the spindles, dis brakes from
Old 03-24-2020, 05:59 AM   #8
notsolo
notsolo's Avatar
If your rebuilding, Rock auto has replacement Moog ball joints etc, at a decent price.
notsolo is offline   Reply With Quote
