Old 03-21-2020, 02:21 PM   #1
j_cst_10
j_cst_10's Avatar
454 TBI lean stumble on throttle tip in
Hey guys, I appreciate any advice.
I have a 91 2500 2wd suburban (square body) 454TBI with the 4L80E trans. It intermittently develops what I can describe as a lean condition stumble (although that may not be accurate but almost feels like a carb with an accelerator pump issue). If you hold your foot on the accelerator at this point it stumbles and bucks depending on load. It appears when the truck is up to temperature. During warm up it is fine. And sometimes it doesn't do it at all!
The truck runs pretty rough when it is initially started and burbles and pops, but then smooths out and drives pretty much completely normal. You can power past the stumble if you put more foot into it.
I have done a simple tune up and replaced the temp sensor in the cylinder head and cleaned the TBI the best I could with spray cleaner.
Anybody else run into this with any of the 454's with TBI?
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
