Old 03-21-2020, 02:53 PM   #1
cdub2010
crooked bed or bent frame?
Finally got my truck back to together. The bed is about 1 inch higher on the pass side and the body lines all seem to line up. I assembled the wood bed on the frame and then tightened everything down. I really don't remember the frame being twisted or bent, it was a replacement frame. What makes more sense? bent frame or crooked bed install?
cdub2010 is offline   Reply With Quote
Old 03-21-2020, 03:00 PM   #2
truckster
truckster's Avatar
Re: crooked bed or bent frame?
How are the body mounts?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-21-2020, 03:08 PM   #3
Sheepdip
Sheepdip's Avatar
If the cab mounts are good... shim the bed to height and forget about it.
Sheepdip is offline   Reply With Quote
Old 03-21-2020, 03:19 PM   #4
kidatheart
kidatheart's Avatar
How does the gap between cab and bed on each side compare? If you shim back of bed you will have to deal with adjusting bumper, too. Could be a difference in rear springs from side to side, also.
kidatheart is offline   Reply With Quote
Old 03-21-2020, 03:32 PM   #5
cdub2010
I just checked the body mounts, looks like this frame was going to be cut down as the body mount brackets are bolted to the frame. Didn't notice that before.
The cab mounts are new poly bushings. The rear springs may culprit, ill have to take it out to flat ground and measure. Im thinking just shim drivers side back bed mount and go from there, since the front bed panel follows the cab trim line fine.
Old 03-21-2020, 04:51 PM   #6
kidatheart
kidatheart's Avatar
I would get it on flat ground and put a jack under the frame at the rear on the drivers side and raise it up a little and see if it squares everything up. Look down the side and see if the body lines are straight down the side and see if the vertical cab to bed gap is even. If so, spring is probably the culprit.
Old 03-22-2020, 12:55 PM   #7
ohboy321
ohboy321's Avatar
I had a similar issue. After putting in new springs my frame was 1/4" lower on the left side, but the bed was off by 1-1/2".
I shimmed the bed level and then readjusted the bumper and exhaust to match.
Steve/NH
1967 K10 327 Short Bed Stepside
2008 F350 Power Stroke Lariat
2007 BMW X3
2023 BMW X3 M-Sport
2020 BMW 540xi M-Sport
1995 Harley FLSTC
ohboy321 is offline   Reply With Quote
Old 03-22-2020, 02:09 PM   #8
chewychevy67
I too had the same problem. Tailgate wouldn't close on the left side properly. I added a 1/4 inch spacer at the last left side bed mount and now it works perfectly.
chewychevy67 is offline   Reply With Quote
Old 03-22-2020, 04:20 PM   #9
c60clf
Likely frame or spring issue, recommend placing on 4 jack stands ,if problem dissapears it's spring problem
c60clf is offline   Reply With Quote
Old 03-22-2020, 05:49 PM   #10
Grumpy old man
Grumpy old man's Avatar
Chevy twist tons of threads on it ,
Chevy twist, pretty common . frame machine to straighten it out or half a dozen different ways to use spacers to make it "look " right
https://www.google.com/search?domain...D%3A1%3B&hl=en
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
