03-21-2020, 04:58 PM | #1 |
Polished 250 Parts
Getting ready to rebuild my 250 inline 6 engine and paint it but cant seem to find a polished fan pulley and fan. Could also use a polished crank shaft pulley. Also a polished alternator. Any other suggestions would be great.
Would love to get some recommendations and pics from those who have already done this. |
03-21-2020, 05:03 PM | #2 | |
It's Better With Nitro
Re: Polished 250 Parts
When I had the L6 in my Chevy II, I sent those items off to the chrome plater. For the alternator, I took mine apart and had the housing chromed, but these days, there are a lot of aftermarket companies that offer really nice assembled alternator units and higher amps with the housing already chromed.
03-21-2020, 05:06 PM | #3 |
Ya Ive been online for days searching but not much luck. I actually have the original generator in my truck. I thought about having it chromed or powder coated.
03-21-2020, 06:04 PM | #4 |
Moderator
Powdercoating will look great, and be less expensive than chrome. Lots of colour choices, including some shiny ones.
03-21-2020, 09:19 PM | #5 |
60-66 Nut
I could be wrong but I thought that the water pump pulley and fan for a 230/250 are the same as a SBC? The alternator would definitely be the same. The crank pulley would definitely be different.
03-21-2020, 10:10 PM | #6 | |
Part number 60-14210 from Orange county truck and car shop. Bit smaller than stock but seems to work fine.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-21-2020, 10:32 PM | #7 |
I have a 250 power steering set up and look the numbers up and it is the same as a sbc for the water pump pulley.
04-03-2020, 07:49 AM | #8 |
Hey tj can you show me an up close picture of how you got your carburetor linked to throttle? I am having a hard time figuring out how to get my Edelbrock setup.
