Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 03-21-2020, 06:18 PM   #1
sweetk30
sweetk30's Avatar
bbc in med duty trucks ?
so over on another board we got a question going . did they ever do 454 std or tall deck factory in c40-up trucks ?
i have always read its a nope and now this flyer popped up from one of the guys showing a gas v-8 7.4L engine .
for square body and older stuff only .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-21-2020, 06:56 PM   #2
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: bbc in med duty trucks ?
Got a 99 gmc c5500 with a 454
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 03-21-2020, 07:28 PM   #3
Pvmt-Pndr
To my knowledge there was never a 454 tall deck. Only 366 and 427s
Pvmt-Pndr is offline   Reply With Quote
Old 03-21-2020, 07:30 PM   #4
sweetk30
sweetk30's Avatar
to new . sorry should have said square body or older only .
Old 03-21-2020, 07:42 PM   #5
b454rat
I think on mortec.com they did list a tall deck 454. If you think there isn't much difference, and of course blocks are the same.
Old 03-21-2020, 07:44 PM   #6
b454rat
10134366...454T..............4-bolt, Bowtie, Gen.V, Tall deck
14044807...454T..............4-bolt, Bowtie, MkIV, CNC prep, Tall deck, 4.25" bore or 4.495" bores
don't think last one counts lol. and first one is late 90s?
Old 03-21-2020, 08:42 PM   #7
Pvmt-Pndr
I stand corrected and learned something new. Thanks
Old 03-24-2020, 01:53 AM   #8
Bob B.
For a few years, starting in 1979, GM did offer a 454 in the C-65/6500 series. Not sure if it was a tall deck or not. There were later Mark V/VI tall deck 7.4L's, and the 8.1L's were all tall deck.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 03-25-2020, 05:56 AM   #9
You ask about BBC but then it seems you are only talking about the 454. There were certainly BBCs in medium duties ever since there have been BBCs. I don't know what years, if not all years, but there certainly were 454s put in medium duty squarebodies. So the argument is about 454, right? Because we all know the 366 was a medium duty-only BBC
Old 03-25-2020, 08:00 AM   #10
95 S_Trucker
95 S_Trucker's Avatar
The L21(98-00 medium duty specific)454/7.4 was a standard deck engine(also Gen VI). All of the L18(01+)496/8.1 engines were tall deck.
95 S_Trucker is offline   Reply With Quote
Old 03-26-2020, 12:34 AM   #11
Bob B.
That makes sense because I think the medium duty L21 used the same intake manifold as the light duty L19 7.4L.
Old 03-26-2020, 04:55 AM   #12
95 S_Trucker
It would be the same intake as the L29. The L19 was TBI.
Old 03-26-2020, 05:27 PM   #13
Bob B.
You are right, typo!
BTW- didn't the L21 have distributor-less ignition?
Old 03-26-2020, 07:41 PM   #14
95 S_Trucker
Yes. It had a big camshaft position sensor where the distributor would be. It had a drive by wire throttle body, and each cylinder had its own ignition coil.
Old 03-26-2020, 08:11 PM   #15
factorystock
factorystock's Avatar
Do these newer 01+ tall deck engines come with timing gears or timing chains? The old 366 and 427 tall decks had timing gears.
factorystock is offline   Reply With Quote
Old 03-26-2020, 09:05 PM   #16
95 S_Trucker
Yes. They have chains.
