My tilt column
I just picked up my tilt column from Les "70Shortfleet". Man was I impressed at his setup. His work area completely organized neat with everything needed to do a professional job. He took my motorhome column and converted it to truck. He even modified the neutral safety switch to use the stock truck one. My truck is a 68 50th but I am changing the color just a tad to 78 Trans Am gold. It is almost the same just a little more sparkle. Took him the paint and sprayed it clear coated and even powder coated the inner shaft. many new parts that he had in stock and a fast turn around time. I almost don't want to install it because it looks so much better than the rest of the truck. I highly recommend Les he does excellent work.
Rick |
Re: My tilt column
Before picture
Old member
That looks amazing! Nice color to.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: My tilt column
Very nice! I'm sure you'll enjoy it....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: My tilt column
I had bought a supposedly rebuilt column from a company, had it painted body color, then installed it.
Once I got the truck on the road I soon realized the column had not been totally rebuilt. I contacted "70Shortfleet", Les, sent him the column, and he got it rebuilt, and sent back quickly. He did a great job for me, and if I had another column to rebuild I would definitely send it to him. My granddaughter was as excited as I was after I got it installed! |
Re: My tilt column
I agree. Les also does gauge clusters. He has made a punch that duplicates the gauge cut outs on the clusters and the tach cut outs to make tach dashes. Also restores consoles.
Re: My tilt column
Unfortunately, I haven’t been able to test the tilt column I got from Les. However, it is a thing of beauty and I have no doubt it will perform as it should. Hell, the “packaging” alone was nothing short of amazing! If he takes the care on shipping his products like he does, I can only imagine the care he takes building the columns. And, he was great to work with. I’m somewhat of a newbie and he answered every question I asked. Great Guy!!
Re: My tilt column
![]() Join Date: May 2005
Re: My tilt column
Quick question... How long a job is the column swap? I have one in my shop and just have been putting it off.
Re: My tilt column
I am also glad to have met Les and am using one of his tilt columns. I just stopped by last week to get an overdrive gear indicator for a my upcoming 700R4 swap. Les is a good guy and fortunately for me just a couple of miles away!
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
Re: My tilt column
JMac
I would guess 2-3 hours. I haven't done mine yet but the hardest part would be to get the old stuff apart. Then it would depend on how much cleaning you plan on doing to it. Tim_MC I am about 2 1/2 hours north of Les and it was well worth the drive. |
