![]() Join Date: Aug 2016
Backing plates with drop spindles
For the guys running drop spindles what did you do for backing plates? Stocks clearly don't fit. Did you all just not run any at all? Thanks
72 C10 lwb fleetside aka Big Rhonda. Still plugging away. Build thread: http://67-72chevytrucks.com/vboard/s...42#post8247142 |
Re: Backing plates with drop spindles
I have ECE drop spindles on my 72 and the backing plates fit fine.
72 C10 lwb fleetside -stock 350/350 combo |
![]() Join Date: Feb 2009
Same on my 71
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Appreciate it guys. Apparently the Cpp modular drop spindles do not use any backing plates according to Cpp. They are intended to be used without the backing plates.
I used the McGaughys spindles and the everything swapped over with no problem. I wonder why CPP would do that?
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
2 1/2 in. 3/4 ton drop spindle. Had a little clearance issue. We just trimmed it a little. Fits fine now.
