72 C10 w/ AC Evap drain hole plug
Hey guys I'm working on my AC vents cables in control unit and putting in a new selector box.
Underneath evaporator there's a hole-in there's a piece of metal can somebody tell me how this is supposed to fit in there? And should I seal it or is this for leakage?
1972 C10 LWB 2WD 307 4 speed Rescued from Field July 2017 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 72 C10 w/ AC Evap drain hole plug
It’s like a trap door. Just muscle back up and leave as is.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
I believe that it's to check the resistors above it to see if they are bad
Ok cool.
I did kinda figure it out and forced it back in. Maybe should have filed the edges a bit to derust it. But it's back in. Thanks guys. Larry
![]() Join Date: May 2010
I always thought that trapdoor was to direct some A/C air to the floor if desired.
Jim |
#6 | |
Interesting thought. May force it back out and clean it up a bit then. Make it easier to swing open.
It's funny because my 67 unit has 2 of them on the bottom I believe. I'll check on that when I get back to my truck. Nope just 1. Must be seeing things
Carpe manana
I imagined it was a weep hole for a possible heater core leak
