Old 12-09-2003, 11:46 AM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Here is a dumb question..
Does the stepside bed sit on those little rubber pads that the fleetside beds sit on. It doesn't look like it does, but I wanted to know for sure.
Hoping to have my bed on in a couple weeks.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-09-2003, 12:04 PM   #2
Mudder
Mudder's Avatar
They have little metal shimms I believe.
Mudder is offline   Reply With Quote
Old 12-09-2003, 01:42 PM   #3
The kit for my bed came with the flat rubber pads. (like a square piece of inner tube). I was told it is optional..I guess it's suppose to help quiet things instead of metal on metal.
Old 12-09-2003, 03:26 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
id definately put something in there i think it would rattle or something otherwise
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-09-2003, 03:35 PM   #5
Randy70C-10
Randy70C-10's Avatar
Mine was bolted straight to the metal.
Randy70C-10 is offline   Reply With Quote
Old 12-09-2003, 05:39 PM   #6
1971Stepside
Almost Satisfied
I think it originally had metal washers and I don't see where the rubber pads would keep noise down as long as the bed was tight to the frame. I was just worried about body lines matching up.
Old 12-10-2003, 04:54 AM   #7
ZOOMY
pads
I just took a stepbox off of a '70 that had never been off before & it had little pads.
ZOOMY is offline   Reply With Quote
Old 12-10-2003, 12:49 PM   #8
1971Stepside
Almost Satisfied
Hmm, thanks Zoomy. I guess I will have to pick me up a set. I bet I could make them out of some old mud flap. I wonder how thick they are?
Old 12-10-2003, 12:52 PM   #9
CPNE
Resident Curmudgeon
CPNE's Avatar
Find an old inner tube and make your own. I bought some several years ago and there were about that thickness
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-10-2003, 12:53 PM   #10
Mudder
Mudder's Avatar
You'll want to wait till you put the bed on to get the body lines straight. Mine just had like 1/8 inch metal plates between the bed and frame.
Old 12-10-2003, 12:55 PM   #11
1971Stepside
Almost Satisfied
I am about ready to put the bed on Mudder! You haven't been up in awhile....
Just doing test fits. I bought two new bedsides and a new RH fender (metal) last weekend. All I need now is a tailgate!
Old 12-10-2003, 01:03 PM   #12
Mudder
Mudder's Avatar
Do you have the cab on?
Old 12-10-2003, 04:39 PM   #13
1971Stepside
Almost Satisfied
The cab is on...
Cab only...
Old 12-10-2003, 04:42 PM   #14
1971Stepside
Almost Satisfied
Cab and Front Clip
Again, just checkin to make sure all my welding allows all things to fit. Luckily, it was all good.
Old 12-10-2003, 07:42 PM   #15
Whooo hoo.....I can hear the engine running. Your getting close dude
Old 12-10-2003, 08:23 PM   #16
hgs_notes
GEARHEAD
hgs_notes's Avatar
When I replaced my bed, I used rubber pads. I also lost some grounding and the tail lights quit working. I added a ground strap which solved the problem.
HG
hgs_notes is offline   Reply With Quote
Old 12-11-2003, 02:34 PM   #17
1971Stepside
Almost Satisfied
That is a good point I hadn't thought of. Thanks for the tip hgs_notes.
