![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
1/2 ton sway bars same as/fit 3/4 ton??
Front and rear with rear leafs for my '69 GMC 3/4. I wanna upgrade the front sway and add a rear sway. Thanks.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: 1/2 ton sway bars same as/fit 3/4 ton??
Are you saying you have leaf springs on the front of your truck ? Whats the diameter of your front sway bar. Most people including me use a 1 1/4 inch front sway bar , as opposed to the 1/2 ton 7/8 inch bars that came on the 67-72's, and get them from a 73-87 Chevy/GMC 1 ton truck. I ask about the diameter of your front sway bar as I don't know if the 67-72 3/4 ton trucks used a 7/8 inch front sway bar. Maybe someone will pipe in if they know for sure.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
I think he is saying he wants sway bars front and rear and the truck is a leaf spring rear.
Either way, your advice is sound.
The Older Generation
Any sway bar will help with driveability whether it is the small diameter or large one. For a daily driver type truck (especially a 1/2 ton) I think the big ones are overkill. As far as fit, the 1/2 and 3/4 ton fit the same on the '67-'72's but I think the bends on the '73 up are a little different. I had a hard time getting a later one to fit the front of the '67 Panel Truck. I don't have a clue about rear sway bars. Just my opinion though, everybody has their own ideas. LockDoc
Sorry. I should be more specific. It's a '69 3/4 GMC with front coils and rear leafs. It has a factory front sway but not one in back. I'd like to upgrade the front but more concerned about adding a rear.
#6 | |
I think there are some threads on here about using a Camaro rear sway bar on our trucks. Read through this thread. http://67-72chevytrucks.com/vboard/s...ad.php?t=30972 It has some pictures of a sway bar on a leaf spring truck. LockDoc
Our 1972 C20 came with a factory 1 1/16 dia. front sway bar. We upgraded to a 1 1/4 dia. 73-87 3/4 Ton front sway bar available at the salvage yard. New bushings from Energy Suspension.
For the rear sway bar we reused a 1" dia. Hellwig 7402 that was already on it. We did reconfigure the front mounts because we've got a FlipKit on the axle. Hope this helps.
