Old 03-23-2020, 12:02 AM   #1
Steve Cole
Can I leave this in place?
Is it okay to leave this zerk fitting in place or should I remove and replace it with a plug? I don't need it for my oil pressure reading. Thanks.
Steve Cole is offline   Reply With Quote
Old 03-23-2020, 04:54 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Can I leave this in place?
I wouldn't leave it. Either get the right plug to block it off or get another bypass block without a hole in it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-23-2020, 08:50 AM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Haha...that's funny....I agree though,,I wouldnt leave it that way either..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-23-2020, 09:29 AM   #4
Steve Cole
Okay, thanks. Any idea what kind of thread that fitting is? Probably something weird.
Old 03-23-2020, 09:50 AM   #5
Steve Cole
I still have my truck pan, I could rob that block from it, it doesn't have that fitting in it. I was trying to avoid having to replace that gasket though.
Old 03-23-2020, 10:29 AM   #6
ls1nova71
ls1nova71's Avatar
It looks like 1/8" pipe thread, the same as most older oil pressure senders. Probably why it was put there in the first place if I had to guess.
Old 03-23-2020, 10:32 AM   #7
Steve Cole
Thanks Eric, you always have the right answers!
Old 03-23-2020, 12:26 PM   #8
Killer Bee
Killer Bee's Avatar
yah, that was never intended to have a grease fitting, it's there to plug what is most likely an 1/8" npt tapped hole..
there are some odd metric grease fitting threads out there but this wasn't intended to be one so more likely npt..
and while it should easily hold the internal oil pressure, I would replace it with a hex plug for the cleanest profile..
in case you even take it to jiffy lube and some dingbat pumps grease in there until it squeezes out of the carburetor
Old 03-23-2020, 07:00 PM   #9
95 S_Trucker
95 S_Trucker's Avatar
Just buy a new factory style bypass. They are cheap, and it will give you piece of mind.
https://www.summitracing.com/parts/nal-12577903
95 S_Trucker is offline   Reply With Quote
Old 03-24-2020, 04:24 PM   #10
LS short box
Don't worry too much about the gasket it's an o-ring. Not to say you can't but I've never replaced the o-ring if it looks like it's in good shape. Having said that they can't be expensive.
LS short box is offline   Reply With Quote
Old 03-24-2020, 11:46 PM   #11
Steve Cole
Thanks for all the great advice guys! I am gonna go with 95 S_Trucker and just replace the block with the bypass style.
Old 03-28-2020, 03:25 PM   #12
LH Lead-Foot
I don’t think Jiffy Lube owns a grease gun in the last 20 years. They never grease any of customers vehicles with dozens underneath. But new sticker, air filter 1” short for the air box and installed a PCV valve too large for the engine size that caused the idle unstable as the IAC was going nuts.
Removed
LH Lead-Foot is offline   Reply With Quote
Old 03-28-2020, 04:08 PM   #13
dayj1
I can’t speak to whether it should be left in place or not (or even why it’s there) but, the grease zerk comes in the bypass plate straight from GM when you buy a new CTSV pan. I know, because I’ve bought 2 of them in the past. Part # 12631828. Here’s the first hit I found in google. You can see the zerk in some of the pictures. http://www.improvedracing.com/oil-pa...1828-p-87.html
dayj1 is offline   Reply With Quote
Old 03-29-2020, 12:32 PM   #14
ls1nova71
ls1nova71's Avatar
The zerk was talked about 10 years ago on LS1Tech, but no one seemed to know what it was for. https://ls1tech.com/forums/conversio...v-oil-pan.html
