Old 03-23-2020, 12:40 PM   #1
4x4swb1970
70 4x4 Rear Springs
Hi guys, I'm in the process of restoring the frame for 70 4x4 K10 short bed. Somebody messed with the rear springs in the past. Right now the drivers side is a 7 leaf with a 5/8" bottom leaf and the rest are all 3/8". The passenger side is a 5/8" bottom leaf and then 3 1/4" leafs and 3 3/8" leafs. Long story short the truck sits crooked, and I want to fix that. If anyone knows what the original springs were supposed to look like I'd appreciate your input. Thx
4x4swb1970 is offline   Reply With Quote
Old 03-23-2020, 06:58 PM   #2
67mater
67mater's Avatar
Re: 70 4x4 Rear Springs
my 67 k10 longbed is 2 full length leaves 3/8" each. Not sure if that's consistent for all years half tons, but I know when I had my k20 it was more like that with the 5/8" overload. your PO was either attempting to change the lift, fix a weak spring, or the normal chevy twist, or all of the above! are you wanting factory ride height or lift?
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 03-23-2020, 07:26 PM   #3
4x4swb1970
Well I really dont have a preferance so I'm kind of aiming at either replacing it to a stock spring and keeping it original, or just going the opposite extreme and putting a lift kit on it. I need rear springs and all 4 shocks anyways. I guess whatever is cheaper is the way I'll end up going. If I can find what an original spring looks like I can see if anyone makes them. It seems like most of what I'm finding are generic springs, and I dont feel like returning 3 sets of springs because they make the truck sit funny! Thx
Old 03-23-2020, 08:03 PM   #4
randy500
Half ton had 4 main leafs and an overload stock, heavy duty spring option would be 5 main leafs and an overload.
randy500 is offline   Reply With Quote
Old 03-23-2020, 08:53 PM   #5
4x4swb1970
Ok awesome, do you have any idea what the thickness of each leaf was. I'm kind of thinking that they were all supposed to be 3/8" leads. Thanks!
Old 03-24-2020, 03:32 PM   #6
KyFarm
KyFarm's Avatar
My truck is a ‘69, but the four springs are 3/8”, the helper spring is 1/2”. These are the thicknesses over the axel.
My truck also has a 1” block between the helper spring and the axel perch.
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 03-24-2020, 07:29 PM   #7
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Hey Buffalo neighbor. Looking at your pictures I see 6-springs + 1-heavy overload in each picture. Anyway here is my K10 after replacement of rear spring set. I went with a Skyjacker 2-1/2" spring lift. Are you planning to reuse the springs? They are 50-year old springs. If you're going through the trouble, why not just replace them with new?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-24-2020, 07:37 PM   #8
4x4swb1970
Well it looks like I'll be going that route. I was debating on whether to go lift or stay stock. I've heard good things about the ride of the skyjackers. If I'm putting lifted springs on, I might as well bite the bullet and get the skyjacker 4" kit. Rough Country is cheaper but it sounds like it's way stiffer of a ride. If you need any parts let me know I have a couple parts trucks kicking around that I dont need much off of anymore! Thx
