power brakes
I want to put power brakes on my 68 C-10 and I'm not sure about the set up. I have 4 wheel drum brakes and I don't want disc on front. Everything I've seen was drum/disc power brake master cylinder. Will the drum/disc master cylinder work on ALL drum or will I have to go with something else? What about the proportion valve; stay the same or change? And, if so, what else would I go with? Can anyone give me a source for a power brake set up for our type trucks? Thanks!
![]() Join Date: Nov 2018
Re: power brakes
Google is your best friend
https://www.classicparts.com/1967-72...20group%20%231 |
Re: power brakes
I have a drum/drum power brake set up I am taking off now. I will send it to you for the cost of shipping if you want it. Original booster, new mc, combo valve, and mounting brackets.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
#4 | |
![]() Join Date: Nov 2019
Re: power brakes
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
Re: power brakes
I wish.
#6 | |
![]() Quote:
Old member
Buy a booster and put it on everything else will work with it. Nothing to add are take off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: power brakes
I'll take it. Thank you! Just send me the information.
