Old 12-09-2003, 01:27 PM   #1
nosto
Flamin' Bass
nosto's Avatar
Temp gauge and sender question
My '67 C-10 orig had the 6cyl, 3 spd and gauges on the dash. When I bought it, there was a 350, 4spd and gauges.
After driving for the last 6 months, the temp gauge has never registered above the 2nd line near the 'C'old, even in 90+ degree weather. Now on 30 degree days, it barely moves off the 'C'.
The sensor on the 350 looks like its the right one for gauges - it's got the little round button type connection.
Sensor reads 800 ohms cold and 45 ohms hot, so I figure I should get more movement on the gauge, but nope.
Does that sound like the right range? Is there a different sensor for 6s and 8s?
Thanks,
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 12-09-2003, 03:10 PM   #2
rage'nrat638
rage'nrat638's Avatar
make sure some bone head did not use teflon tape on this sender
has to be grounded to the engine....
and if you want a new temp. gauge i got one that i will part out of the bezal i had for sale....
mark
rage'nrat638 is offline   Reply With Quote
Old 12-10-2003, 01:02 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What temp is your T-stat?
These guages work on a graduated scale. The needle won't hardly move untill you hit 185 ish and then from 185 to 200 will take up 75% of the needle sweep. (rough estimate on the numbers...but you get the idea)
If you have a 160 T stat, the needle will hardly move at all.
A 180 would do about what you describe.
