Old 03-25-2020, 08:50 PM   #1
G8rN@te61
Edelbrock 1404 Linkage
Getting parts together to install a Edelbrock 1404 onto a offy intake. The offy linkage came with a throttle wire with a ball on the end of it. What is the part I need to get it to attach to the throttle arm on the carb?
Ive done searches and looked at hundreds pf pictures but don't see anything. Some kind of stud that would accept the ball end and screws to the linkage.
thanks in advance
-Nate
G8rN@te61 is offline   Reply With Quote
Old 03-25-2020, 09:04 PM   #2
geezer#99
geezer#99's Avatar
Re: Edelbrock 1404 Linkage
Depends which size ball you need there’s a couple on here.
https://quadrajetparts.com/throttle-...c-228_936.html
Old 03-25-2020, 09:22 PM   #3
G8rN@te61
well the issue is the cable has a ball on the end of it so I need the stud or whatever its called that will attach to the carb arm and hold the ball end of cable. These studs in your link are the opposite with the ball end on them. Do I just snip the ball off the end of the wire and crimp something else on there?
Old 03-25-2020, 09:44 PM   #4
geezer#99
geezer#99's Avatar
My bad.
Your pic is fuzzy.
Thought the ball was hollow.
What or who’s the manufacturer of the ball?
Old 03-26-2020, 06:33 AM   #5
G8rN@te61
it came with the offy intake
Old 03-26-2020, 08:59 AM   #6
geezer#99
geezer#99's Avatar
Are you converting to a complete cable linkage from the loud pedal to the carb or just piece it togethor?
Old 03-26-2020, 09:37 AM   #7
G8rN@te61
both actually. here is current rigged setup
Old 03-26-2020, 10:17 AM   #8
geezer#99
geezer#99's Avatar
That can be tricky setting up.
I didn’t use the bellcrank offy uses. I used an adjustable one mounted to a bracket attached to the carb studs and kept it all solid (no cable).
I found a couple pics.
https://67-72chevytrucks.com/vboard/...ight=Bellcrank
http://67-72chevytrucks.com/vboard/s...d.php?t=651079
Old 04-03-2020, 09:19 PM   #9
DPowers
DPowers's Avatar
May help. One is Holley and one is Edelbrock.
DPowers is offline   Reply With Quote
